Old 02-24-2013, 05:33 PM
Last Online: 03-27-2013 06:26 PM
Default 97 cr250 trans oil
what wieght oil do i use in trans ?
Thx Ron
Old 02-24-2013, 05:36 PM
Young Gun, But A risky One
Last Online: 05-23-2013 10:30 AM
My 91 cr 250 calls for SAE 20W-50 weight oil
Im assuming it may be the same for yours
Old 02-24-2013, 06:28 PM
bbrmotosports's Avatar
Rockin A class
You can use anything from automatic transmission fluid to 80-90. I used to use the honda HP trans fluid in my honda but switched to Skilolene for everything.
Old 02-26-2013, 01:03 AM
shrubitup's Avatar
Last Online: 06-29-2017 12:57 AM
Use ATF or Rotella/Delo 15W-40 - whatever.
Old 02-26-2013, 12:14 PM
all of the auto and diesel products are cheap to try. stay away from anything that claims to be energy saving with that EC seal on it is all,,,that is all motor oils from 5-30 on down, ie 0-20, 5-20 etc. your bearings and gears can live on it, but the clutches sometimes start slipping.
find one that shifts and clutches the way you like for your particular bike. change it often.
Similar Threads for: 97 cr250 trans oil
1995 cr250 trans fluid milky? And clutch problems. ianm1982 2-Stroke Dirt Bikes - Honda 13 02-06-2012 10:35 AM
Help 95 CR250 Mystery trans part Tuck 2-Stroke Dirt Bikes - Honda 2 10-19-2011 05:31 PM
Noise in trans. Cr250 wiztech5978 2-Stroke Dirt Bikes - Honda 2 06-18-2011 07:19 AM
96 cr250 trans capacity? 96-CR250 2-Stroke Dirt Bikes - Honda 4 01-27-2011 06:11 PM
96 Cr250 Trans capacity? 96-CR250 2-Stroke Dirt Bikes - Honda 0 01-27-2011 03:25 PM
