Old 02-22-2013, 08:54 AM
Last Online: 03-27-2013 06:26 PM
Default 97 cr 250 water pump
is it best to install water pump shaft in the clutch cover case before installing the clutch cover case on engine ?
and also will the kick starter sping stay in place while im installing the clutch cover case ?
Thx Ron
Old 02-22-2013, 12:33 PM
Last Online: Today 08:22 PM
Default OK
Ok, the shaft and seals as well and the bearing plus the impeller all should be installed the large clutch over before you install the cover. As far as I know there is no other way to do it. Then you just have to rotate the impeller to aline it for the cover to go on.
Yes the clutch spring should stay in place.
You really need a service manual for your bike!
Similar Threads for: 97 cr 250 water pump
water pump adam32 2-Stroke Dirt Bikes - Honda 8 12-11-2012 11:13 AM
93 cr250 water pump kmaxwell 2-Stroke Dirt Bikes - Honda 3 02-09-2011 03:20 PM
2005 CR250 Water pump releasing water benkm108 2-Stroke Dirt Bikes - Honda 4 01-05-2010 08:14 PM
250F leaking water from bottom of water pump lsqrus 4-Stroke Dirt Bikes - Yamaha 2 09-09-2007 01:05 AM
rmz 450 water pump casey392 4-Stroke Dirt Bikes - Suzuki 1 08-30-2005 06:23 PM
