Old 12-22-2018, 12:47 AM
Last Online: 02-05-2020 05:58 AM
Default 96 cr250 power valve set up
I'm having trouble keeping the clearance when I adjust the spring at the top . I loosen the pinch bolt and rotate the arm to get the .50mm clearance between the pinion spring and the pinion lever then tighten it up , but as soon as I let go of the arm it springs back hard to the rod and there's no gap. Any suggestions .
Old 01-02-2019, 10:54 AM
dogger315's Avatar
Could be a problem with either the set screw itself or the lever arm that prevents an actual tight fit on the pinion shaft. Try setting it without the spring installed and see when you rotate the shaft if the lever arm follows. If not, you'll need to buy some replacement parts.
Similar Threads for: 96 cr250 power valve set up
Cr250 Power Valve Components. Various. Eye Cell Classified Ads 0 03-30-2013 02:23 PM
power-valve help on 91 cr250 puggerton03 2-Stroke Dirt Bikes - Honda 0 07-21-2010 04:39 PM
power valve help cr250 1990 wortho32 2-Stroke Dirt Bikes - Honda 4 08-09-2009 04:53 PM
2001 cr250 power valve help 1motoman69 2-Stroke Dirt Bikes - Honda 1 07-04-2009 08:41 AM
98 cr250 power valve?????? larensdad 2-Stroke Dirt Bikes - Honda 5 10-02-2008 12:57 PM
