Old 09-12-2012, 04:18 PM
bidphoenix's Avatar
Last Online: 10-15-2012 02:57 PM
Default 96 CR 250 Ignition swap ?
Hey, just wondering if and how could i swap out my 96 ignition for a newer one say like the 2000 ? I've searched the forums and notice a few people talking about it. But no one really went into detail just curious if its actually possible to do and if it is how hard will it be ? My reasoning for this is that the 96 ignition is giving me boat loads of trouble. i have bought 2 cdi's and 2 ignition coils already and countless plugs to no prevail, the reading on the ohm meter appear fine but no spark comes out at all .. So with that reason i want to swap out for a newer digital ignition system Thanks so much if anyone could help or share words of wisdom !
Old 09-12-2012, 04:49 PM
dogger315's Avatar
Last Online: 01-11-2019 07:51 PM
97 and up are digital, so any of those will perform better than your analog
unit. All through 2001 are direct swaps. You will need the stator and Ignition
controller. The coil you have is the same and should work fine (unless you
suspect it might also be bad).
Good luck finding a digital unit for a good price, all the 500 riders are buying
them up.
dogger
Old 09-12-2012, 05:11 PM
bidphoenix's Avatar
Alright sounds good thanks for the information ! , On a side note my igntion pulse coil is getting 100 ohms but the book says i should be getting 180-280. Could this cause no spark ?
Old 09-12-2012, 06:48 PM
dogger315's Avatar
coil is getting 100 ohms .... Could this cause no spark ?
Yes. Time to swap it out.
dogger
Similar Threads for: 96 CR 250 Ignition swap ?
Ignition swap 97 rm250 njboost 2-Stroke Dirt Bike Forums 0 02-24-2012 08:59 AM
Pre ignition?? kxmoto4life 2-Stroke Dirt Bike Forums 5 03-17-2008 07:29 AM
99 CR 250 IGNITION micro101 2-Stroke Dirt Bikes - Honda 0 06-22-2007 04:34 PM
FMF Ignition 99kx250rules General Discussion 7 06-12-2005 03:39 PM
cdi ignition?? rookie450er 4-Stroke Dirt Bikes - Honda 5 12-02-2003 09:16 AM
