Old 01-15-2016, 12:10 AM
Last Online: 05-09-2019 01:47 PM
Default 94 CR 250 Full Restoration
I am putting some parts together for a complete restoration. One of the steering stops is broken on my bottom triple clamp. I know the 95 250 uses the same 43mm forks but in 95 the 250 and 500 triple clamp width increased by 5mm. Did the 95,96,97 cr 125 steel frame keep the same width triple clamp or did they get the 5mm wider triple clamp in 1995 like the 250 and 500?
I have found a 95 cr 125 applied top triple and I need to know if I need a 94 bottom triple or a 95 bottom triple to bolt onto my 94 250.
Old 01-15-2016, 04:18 AM
mine was broken off too, a good welder/machinist sort me out, then shape it similar with the other stopper and you're done
Old 01-18-2016, 11:12 PM
Thank you, I may just get mine repaired too. It seems that all,the triple clamps on the 95 Cr bikes, 125,250,500 were widened by 5mm even though they were still using 43mm forks. Also, this was the year that one of the steering head bearings was bigger on the bottom clamp, then around 97, Honda went back to using the two smaller bearings on the top and bottom triple clamp like the 1994 and prior models. So, this increased 5mm width is one of the reasons that the 95 triple clamp part number is different.
Old 01-19-2016, 09:57 AM
dogger315's Avatar
Last Online: 05-12-2019 06:25 PM
You have a couple of options. Repair the stop which will return function to
the clamp but probably not be ideal aesthetically, or replace the clamp with
a decent used part from Craig's list or EBay. It comes down to the level of
restoration you're shooting for.
Old 01-20-2016, 12:41 AM
It will be a full restoration. I have a couple of leads on an umdamaged replacement. I have collected a lot of parts already. I have a new oem 96 cylinder still in the box from Honda along with a lot of other stuff.
Old 01-20-2016, 08:40 AM
dogger315's Avatar
Keep in mind clamps from 92-94 are identical. I see good candidates pop up
all the time. You only need the clamp itself as long as your existing stem is
in good shape.
Old 01-22-2016, 08:29 PM
in good shape.
The stem is in good shape. I am working on a replacement.
Old 01-24-2016, 06:47 PM
I need a little help. I am almost ready to buy an IMS wide transmission kit for my 94 CR 250. I have read some posts that there was a change in 94 back to a wider range transmission which continued through production in 2001. Does anyone know the gear ratios on the 1994 and the gear ratios on the IMS transmission.
I read the July 92 Dirt Bike Magazine test on the IMS wide ratio transmission installed a 92 Cr 250 but it doesn't specify the IMS gear ratios.
---------- Post added at 06:47 PM ---------- Previous post was at 05:59 PM ----------
Update. What I read on some other posts in some other forums was incorrect information. I checked the Honda parts fiche and the 92 CR 250 transmission and the 94 CR 250 transmission have the exactly the same parts numbers. So, I answered my own question.
Old 01-25-2016, 08:19 PM
JMV's Avatar
JMV JMV is offline
Always nice when someone posts a question but is actually willing to put some effort into solving their own problems.
Where are you getting this IMS kit from? I searched ebay and the like for months and never saw one pop up. CRF's only sells a kit for CRF450's but was never able to confirm whether or not it would fit and didn't want to do a $600 science experiment.
Old 01-30-2016, 11:14 AM
Thanks for the nice comment! I will try to post some pictures of the IMS Kit in a few days. I have another question, I want to buy a complete UFO plastic kit, fenders,shrouds, side panels, fork guards but I want all the parts in red. Does anyone know where I can buy the kit in all red? Also, are "flo red" and "nuclear red" the same color?[COLOR="Red"]
This is how the old girl looked when I picked her up. The owner had purchased the bike and after partial disassembly decided it was a little too much work for him. He was correct in a lot of ways. I have never seen a bike that had been rode into the ground bc of lack of simple maintenance. I don't think the bike had been washed since 1994 when it left the Honda dealership. The air filter came apart in your hands, the shock linkage was seized, the front brake line was held to the front fork tube with six white zip ties, the rear sprocket bolts were SAE not metric, the gear shifter looked like it came off a Z50, the spokes on both wheels were seized, the tip of the brake pedal was held on by two SAE bolts of different sizes. I could go on and on and on.
It was in pitiful shape but I couldn't leave it there and under all that I could see a steel framed Honda two stroke racing machine
It was definitely a hare scrambles bike, look at the letters on the back fender.
When I got home, I went "Tony Montana" (Say Hello to my little friend..) on the seized shock linkage.
The linkage was seized to the frame and the suspension link
Engine case had damage near shifter assembly.
As I suspected the inside of the case had some damage too. The internal main shaft bearing area was damaged as well.
Similar Threads for: 94 CR 250 Full Restoration
1984 Honda XR 250-new project-full restoration! stevo450 Dirt Bike Restorations and Builds 366 11-13-2016 07:52 PM
85 CR 500 budget restoration jbsleddin 2-Stroke Dirt Bikes - Honda 22 05-29-2012 06:34 PM
More '79 restoration pictures dogger315 Dirt Bike Restorations and Builds 22 11-04-2011 10:23 AM
85 cr 250 restoration oglejust 2-Stroke Dirt Bikes - Honda 16 08-27-2008 11:57 AM
77' DT 100 restoration lgyee4 Vintage Riding 25 04-22-2004 06:30 PM
