Old 05-17-2013, 07:42 AM
Last Online: 01-22-2019 12:16 AM
Default 93 CR250 Rear Shock Upgrade to 96 Model
When upgrading the rear shock on a 93 CR250 to a shock from a 96 CR250, is it required to use 96 linkage also? I'm trying to do the shock upgrade, but the nut for the lower shock mount hits adjacent linkage.
Thanks,
TC90
Old 05-18-2013, 11:42 AM
dogger315's Avatar
Last Online: 08-31-2019 06:04 PM
I wouldn't call it an "upgrade", but yes, the linkage will have to be changed
as well. It's a shame you couldn't find a way to rebuild your 93 shock because
the 93 linkage ratio combined with the frame geometry was the best of all the
steelies, IMO.
dogger
Old 05-19-2013, 07:55 PM
Dogger-
Thanks for the advisement on staying with the 93 shock. I thought that going with the 96 setup would be a plus because of the addition of the High Speed Compression adjustment that became available on the 95-96 steel framed CRs. If the "96 Upgrade" does not work out, guess I'll go back to the 93 shock. Though, I'll need to replace the 93 shock body because it is worn and at its service limit.
Thanks,
TC90
Old 05-25-2013, 05:10 AM
So, I've discovered that 96 CR250 Linkage does not fit into my 93 swingarm. The options seem to be get a 96 swingarm or maybe use the dogbone from the 96 and the shock arm from the 93. From what I had seen in the Forums , it sounded like swap was straight forward, maybe I mislead my self a bit. Thanks for your help in advance.
Old 05-25-2013, 11:47 AM
i was looking at my 93 a couple of years ago and stuck the swingarm from a 2000 on the frame. wouldnt take much to make that work, since i have all the linkage and a shock. then i found an NOS 93 swingarm, and didnt make the switch. you have me interested again now though.
Old 06-01-2013, 09:21 AM
Last Online: 06-23-2013 02:13 PM
Default 95 cr250 shock
Anyone have a shock for a 95 cr250 for cheap??
Similar Threads for: 93 CR250 Rear Shock Upgrade to 96 Model
96 cr250 rear shock fitment livetoride21 2-Stroke Dirt Bikes - Honda 7 11-17-2012 03:53 PM
Help please: assembly guide for CR250 rear shock: shock spring, retainer seat, lukecrf450 2-Stroke Dirt Bikes - Honda 10 10-04-2012 11:37 AM
96 cr250 rear shock red96 Classified Ads 2 04-18-2011 05:46 PM
95 cr250 rear shock sickboyjerry Dirt Bike Suspension Tuning 0 09-18-2009 06:33 PM
96 CR250 Rear Shock 2old4a250 Dirt Bike Suspension Tuning 3 06-28-2005 01:33 PM
