Old 01-14-2013, 08:25 PM
Last Online: 09-22-2019 09:19 PM
Default 93 cr250 rear brake leak
my rear brake caliper leaks. i think around the piston. i might replace it.
would i benifit using one off a newer model. anyone know what years will bolt up. im going to replace the rotor too .
or are the rebuild kits easy to install?
Old 01-14-2013, 08:44 PM
Last Online: 07-09-2013 10:29 AM
The rebuild kits can go either way but if your is leaking around the piston it should be a easy rebuild
Old 01-14-2013, 08:53 PM
stevo450's Avatar
Rebuilding calipers is not too hard, provided you have a manual to guide you along....
Most times the oil seals go bad, and leaks make the brakes run like junk, a rebuild possible new pistons and new rotor and pad should make a difference. The only thing you may find to be extremely tricky are the screws and bolts that may have rusted....this has often become for me a two or three day job as opposed to a two hour job.
Old 01-15-2013, 09:34 AM
dogger315's Avatar
Actually, your 93 caliper and master cylinder provides superior
braking in comparison to the newer models. Honda went for
light over power in subsequent years and the rear brakes come
up short. Like others have said, a rebuild kit and some quality
bench time and you'll be good to go.
This is a good idea. The rotor from a 2000 CR or later will bolt
on with just a little grinding on the carrier and yield much better
power. It's the same diameter rotor Team Honda used in the
early to mid 90s.
dogger
Old 01-22-2013, 04:32 PM
thanks for the good advice. i will order a rebuild kit for the caliper.
i looked at some rotors on ebay, some look real cheap but not too sure.
anybody recommend a good all around rotor. a place to buy from or brand name, are the chinese ones good enough ?
Similar Threads for: 93 cr250 rear brake leak
2000 CR250 Rear Brake leaking fluid ridz90 2-Stroke Dirt Bikes - Honda 3 12-03-2011 08:27 PM
cr250 rear brake master cylinder ed_563 2-Stroke Dirt Bikes - Honda 0 10-05-2010 03:15 PM
1999 rear shock leak nathan 2-Stroke Dirt Bike Forums 2 12-13-2007 11:14 PM
89 CR250 Rear Brake Question Tonyklem 2-Stroke Dirt Bikes - Honda 7 07-06-2007 07:24 PM
Tapping the Rear Brake crfjedi393 Dirt Bike Riding Tips 19 04-11-2007 07:42 PM
