Old 01-16-2013, 11:08 AM
Last Online: 07-09-2013 10:29 AM
He stated dry which is y I keep saying fuel
I've repaired many dented pipe but as stated be carefull as if u fill it to full it will split the pipe then u have to pound it back togather and reweld it...
I used a 1 gallon oil jug cap wraped in duct tape till a tight fit then duct tape it in the big end of pipe fill 7/8 full with water or a bit more not full! Then I used a quart oil jug cap the same way wrap in duct tape till a tight fit and again tape it in..freeze solid this may take a few attempts
If u can c any light thru the reed tips and cage time to replace
Old 01-16-2013, 11:14 AM
cant see the pic
maybe it is my patience level and since i can get the dents out in minutes with a torch i should have tried more than 5 or so times. never saw any movement with the standard fill and plug method unless the pipe was plugged and FULL of water, then breaks. for the most part i have just watched others with zero results. the ice doesnt get much traction on an oily pipe it seems.
Old 01-16-2013, 11:19 AM
Here is a pic of a pipe I tried this method with i over filled it and it split u can c where I welded it back up and cleaned the weld off
I used a gallon oil jug cap wrapped in duct tape till tight then tape in place same as the little end only a quart oil jug cap this may take a few attempts to get good results
---------- Post added at 12:19 PM ---------- Previous post was at 12:17 PM ----------
Sorry out in the garage my phone is giving me crap
U can c where the dent was it was big too! About the size of a softball lol
Old 01-16-2013, 11:21 AM
pretty nice work. the ice didnt do too much of though from the sounds.
Old 01-16-2013, 11:27 AM
^ thank u it aint the pertiest but works.
The split went from the factory seam all the way to the pro circuit plate welded in the middle it Kinda followed the edge of the dent
Old 01-16-2013, 11:33 AM
about the only ones that moved dents at all were so full that they split too. with a few bilge plug type xpando plugs i was always able to get them out with the torches fast, so maybe i never really developed the skills for freezing them out. lots of my friends tried it and ended up using the torches more often than not, or just ran with the dents.
Old 01-16-2013, 11:39 AM
I also live in a very cold climate compared to u guys down south I like to let mother nature freeze my pipes as -10 seams to really expand the ice
Old 01-16-2013, 11:40 AM
yep, lol, we guys downsouth,,,tell me about -10
Old 01-16-2013, 11:41 AM
Have u let alaska'a temps try it or only a freezer? I learned this from a old sled racer
Old 01-16-2013, 11:49 AM
i just use the shed. never have cleaned out the freezer inside enough to try one. i have this old yz125 pipe that i keep letting others try it on. tried it again earlier this year when someone was raving about it, i think it has ahd about 30 shots now lol
Similar Threads for: 90 cr250r starting prob
Air box prob and trans prob? Tommyramone55 2-Stroke Dirt Bikes - Kawasaki 23 02-01-2012 01:10 PM
need help, asap, top end prob rodogg 2-Stroke Dirt Bikes - KTM 4 11-03-2010 03:00 PM
throttle prob vincexxx77 General Discussion 0 07-21-2007 02:37 PM
kmx 125 prob Cr125zrule 2-Stroke Dirt Bikes - Kawasaki 7 03-27-2006 03:33 PM
betcha never had this prob madcow393 2-Stroke Dirt Bikes - Honda 4 07-12-2003 06:11 PM
