Old 08-29-2011, 04:00 PM
Last Online: 04-12-2012 10:10 AM
Default 89 CR125 help
Hi, my 1989 CR125 has recently started to run funny. It seems to be losing power at high rpm but not at low or mid range, at top rpm it starts to sputter but not all the time. The bike starts easy and runs great right up until the high revs.
At first I though the bike just needed a rebuild, but after finding that it still 125PSI at the top end, now i'm not so sure. I was thinking it could be electrical or it could the power valve (ATAC) stuck. Any ideas?
thanks
Old 08-29-2011, 04:04 PM
dodging_roost's Avatar
Last Online: 05-30-2018 07:46 PM
thanks
The ATAC units didn't really work very well, and if it was stuck open it would theoretically be where it worked better on the bottom end than the top. You should be able to pull the bottom of the unit and see if it is moving as you rev the motor.
Have you looked at your carb and the float to check the height?
Thanks
scott
Old 08-29-2011, 04:49 PM
Default Compression
Your compression is a bit low and thus you may be seeing blow by at high rpm. You should be at about 160psi compression. At 125 psi it should run, but not real good at top rpm and may seem to bew running rich.
Old 09-05-2011, 02:31 PM
Hi everyone, I found out what the problem is. I had lost a special bolt that goes in the cylinder to stop the power valve from moving to far and opening the power valve a high RPM, It must have vibrated out.
But anyway I decided to rebuild the top end since i need the special bolt (which honda discontinued) for it to run proper anyway.
so I got her stripped down and the piston doesn't look to bad but the cylinder does. I noticed that i can still see the marks from when it was honed or whatever but only on the sides, not around the intake or exhaust ports. Is this normal? i'm guessing not.
Worst of all the cylinder bore seems to be out. I don't have an inside micrometer so i just placed the piston ring inside the cylinder and used the piston to push it down in 1/4 increments. Around have way down the cylinder the ring end gap opened up big time, I just eye-balled it.
What now? can i bore nikisil? or do i have to send it for re-sleeving?
thanks guys
Old 09-05-2011, 03:37 PM
supercr125's Avatar
Last Online: 03-02-2016 12:12 AM
look around, dont get it sleeved, get it bored and replate it. you can buy a piston a bit oversized and send it with the cylinder and they will bore it out and plate it to match that piston exactly. i did it with my rm250 i replated. thats your best bet, getting a cylinder sleeved isnt the best thing to do to a bike...
Similar Threads for: 89 CR125 help
Will a cr125 1997 left crankcase fit to a cr125 2000 right crankcase? beont 2-Stroke Dirt Bikes - Honda 3 05-20-2011 10:19 AM
2001 cr125 vs cr125 2002 barty5 2-Stroke Dirt Bikes - Honda 1 08-03-2010 07:34 PM
need help with my cr125! 2001hondacr125 General Discussion 2 01-20-2008 07:15 PM
HELP cr125! 2001hondacr125 2-Stroke Dirt Bikes - Honda 1 01-15-2008 10:51 AM
05' vs 07' cr125 i_get_roosted 2-Stroke Dirt Bike Forums 2 03-01-2007 12:43 PM
