Old 06-13-2005, 09:12 AM
mtk's Avatar
mtk mtk is offline
Default Re: 250-125 engine swap
Given that the CR250's Showa suspension has been ranked as some of the best ever for quite a few years, I don't buy that explanation at all.
The CR125 frame, however, is a few pounds lighter than the 250 version, which is why they chose it for the Limited Edition model. Personally, I think they should have put Ohlins suspension on the LE model, but that's just me.
I'm using a 2000 CR250 chassis for mine.
Old 06-13-2005, 10:17 AM
jgbike's Avatar
Last Online: 04-19-2017 08:25 PM
why not disconnect power valves,that will kill the hit
Old 06-13-2005, 11:12 AM
alex83's Avatar
Banned
Last Online: 08-08-2005 08:52 PM
Well that's just what TWMX said so don't ask me, something about it offered a more rider friendly package out of the box.
Old 06-13-2005, 02:38 PM
Last Online: 05-19-2014 04:10 PM
Putting a 125 motor in it will be expensive and it will still be scary. You would probably be better off taming the 250 motor. Put a 14oz flywheel weight on it for starters. Retard the ignition timeing. This may tame it enough to make you happy, if not there is more you can do. You can remove the pv govenor and wire (or otherwise secure) the pv's shut. This will totally kill the mid-top end, but will allow it to run ok at low rpms.
good luck
Old 06-13-2005, 11:34 PM
seamonkey's Avatar
Last Online: 04-17-2007 04:27 AM
I haven't been able to check the thread in a couple of days. Some great suggestions, thanks. I think I'll probably try to tame the 250 first. So disabling the power valve should cork it pretty good.
Old 06-14-2005, 06:21 AM
Yes, but you have to make sure it stays closed, keeping it open would kill the botom and make a tremondous mid-top hit.
More flywheel inertia will make a big difference as well.
good luck
Old 06-14-2005, 10:13 AM
mtk's Avatar
mtk mtk is offline
Leave the powervalve alone and order the heaviest flywheel weight Steahly has to offer. That will help tame it and not mess things up mechanically.
Old 06-14-2005, 11:29 AM
Removing the linkage and locking it open is easy. Eddie Cole makes some plugs that will do it too. The problem you face then is jetting the top end as you now will have more compression as you go up in the rev range. Just something to think about, and your gf likely will not be holding it wide open for long,,but just remember that if anyone else jumps on it and finds that it doesnt have much power they are likely to hold it open and fry it.
I occasionally see someone talk about gearing a bike up to teach someone to ride,,and I dont agree with that at all. more novices kill bikes and get frustrated because they cant get rolling than over gas them. Or rather until they kill it several times and then try to get moving by over throttling etc. I have way better luck in gearing one down so they pull away easily,,most new riders and women in particular are way more throttle cautious than throttle happy,,just my two cents from teaching others to ride since 66.
Old 06-19-2005, 07:39 PM
seamonkey's Avatar
I think I came up with a better idea. I'm going to teach her to ride the yz450 and I'm going to ride the cr if and when I get her to ride. I hate to put her on my new bike, but it seems the best answer. Learning a four stroke is so much easier. Still a TON of power but no hit, and like you say she probably won't be much on the gas anyways. Now if only I can convince her that she only has to reach the foot pegs and not the ground to ride it.
Old 06-19-2005, 09:13 PM
mtk's Avatar
mtk mtk is offline
I think you're looking at this all wrong.
The girlfriend wants to ride.
This is a perfect excuse to buy a XR50 pit bike to teach her to ride on. No one says you have to sell it once she learns. A small 50 is a hoot in the backyard.
Similar Threads for: 250-125 engine swap
YZ WR engine swap mboyd 2-Stroke Dirt Bikes - Yamaha 1 03-10-2009 08:07 AM
CR80 to 125 engine swap TJpwr 2-Stroke Dirt Bike Forums 34 01-23-2008 07:10 PM
husky engine swap tchui General Discussion 8 01-16-2008 11:58 AM
Engine swap? Unb3li3v4bl3 2-Stroke Dirt Bikes - Kawasaki 10 12-26-2007 10:42 AM
engine swap billd 2-Stroke Dirt Bikes - Kawasaki 6 04-07-2007 08:00 AM
