Old 07-14-2017, 04:54 PM
Last Online: 08-15-2017 12:33 PM
Exclamation 2004 CR250R coolant leak and broken stud HELP!!
Ok so I just bought a 2004 cr250. It's a beautiful bike and I got a decent deal. But now the head gasket leaks coolant. I changed the gasket and it still leaks. It's probably due to the stud in the cylinder that is free spinning but won't thread in or out. I need advice on how to get it out and replace it.
Old 07-14-2017, 10:14 PM
bjunior's Avatar
novice
Last Online: Today 12:13 AM
They make a special tool to remove those studs unless the stud is broke off that's a bigger problem.also is the head flat or is it messed up. i laid my head on a flat piece of glass .
Old 07-15-2017, 05:45 AM
The stud seems to be broken. I can wiggle it up and down, and it just spins. But I can't get it out. Usually I just thread down two nuts to take them off but I don't know how to deal with this one
Old 07-15-2017, 02:32 PM
schwen_108's Avatar
Retired from offroad
Last Online: 11-22-2019 02:42 PM
If I were in your shoes, I would sit tight and hope that PawPaw replies to this thread. That man's a Honda guru
Old 07-16-2017, 05:48 AM
Try the two nuts technique but with the difference that you have to unthread by pulling upwards the nuts so the stud can find a "decent" thread.
Old 07-16-2017, 04:12 PM
Last Online: 05-26-2020 06:43 PM
Like byronk said, you need to double nut the stud and pull up as you try to unthread it. Once it is out you can use a heli coil type insert to repair the threads.
Old 08-15-2017, 12:33 PM
Thanks guys. It's all taken care of. The free spinning studs just pulled right out with a little force. I installed a helocoil in each of the stripped out holes and put it all back together. Runs perfect now
Similar Threads for: 2004 CR250R coolant leak and broken stud HELP!!
cr250 coolant leak help! ianm1982 2-Stroke Dirt Bikes - Honda 10 01-20-2012 01:02 PM
2004 yz85 coolant leak robeau36 2-Stroke Dirt Bikes - Yamaha 7 06-09-2010 07:41 PM
Coolant Leak CR125Phil 2-Stroke Dirt Bikes - Honda 10 02-02-2010 10:58 AM
Coolant leak! Please help!! Motocrossboy10 2-Stroke Dirt Bikes - Suzuki 7 08-16-2007 09:15 PM
Coolant Leak on YFZ Woody_YZF ATV/UTV - Yamaha 28 04-16-2004 01:07 PM
