Old 04-08-2017, 11:46 PM
Last Online: 04-14-2017 09:51 PM
Default 2002 XR200R Bogs Down On Throttle
I am in need of some help. I bought a 2002 XR200R that had been setting in a garage for about 5 years without being hardly ever ridden. At first it would not idle for more than 5 seconds before dying. I've taken the carburetor off and cleaned it, it was very dirty inside! The pilot jet was clogged and I couldn't get it unclogged, so I bought a brand new one at the local shop and got it put in. The main jet was also clogged, but I was able to clear it out by soaking it in some gasoline. The float needle was also a little stuck at first, but I gently removed it and soaked it and the float in gasoline, too. I also cleaned the inside of where the needle goes as best as I could. Other things I've also done are clean out the air box and replace the air filter, change the spark plug and change the oil.
Now, the bike will crank no problems. I don't even have to use the choke to get it started. The issue is when I'm riding it and twist the throttle. Starting off, no issues. But getting into the higher RPMs in any gear, it starts to bog down. BUT, I can let off of the throttle and twist it at full throttle again and it seems to pull through and be fine.
I don't know where to start. Could the main jet still be partially clogged? I'm not too familiar with this carburetor. Does it have different adjustment screws for the air/fuel mixture? Or just an adjustment screw for the idle? (Which, starting and idling isn't a problem.) The intake boot is on pretty good as best I can tell. The one thing I haven't checked is to see if there is any blockage inside the boot between the air box and the carburetor.
Other than checking the main jet again, to clear the carburetor as the cause for problem, am I better off just replacing the whole carburetor? Because I know that thing has more holes in it that fuel flows through. Those could be clogged, too, maybe?
Thanks!
Old 04-09-2017, 09:36 AM
Last Online: Yesterday 07:54 PM
If your jets were clogged, then so will be the very small passages in the carb. A good rebuild is in order including the float valve.
Speaking of which, the float will need to be reset.
The fact that the bike starts with out the choke indicates you are rich.
The bogging with throttle tells me lean.
Old 04-14-2017, 09:51 PM
I found the problem. I hadn't used brake cleaner and an air compressor on the disassembled carburetor up until after this post. There was some trash stuck inside the fuel inlet "tunnel" that's inside the carburetor housing. A little bit of brake fluid and a puff of the air compressor blew it right out! Now there's no bogging/hesitation whatsoever! Thanks for the help!!
Similar Threads for: 2002 XR200R Bogs Down On Throttle
ZB 50 Bogs at Full Throttle akdenali118 4-Stroke Dirt Bikes - Honda 1 07-13-2013 03:52 AM
LT50 bogs under full throttle merc1100sc ATV/UTV - Suzuki 4 10-29-2012 08:08 AM
2002 xr200r won't idle SLaCkLiNeR44 4-Stroke Dirt Bikes - Honda 26 10-29-2012 07:54 AM
2000 RM 250 Only Bogs At Full Throttle Tucraysz2 2-Stroke Dirt Bikes - Suzuki 6 10-07-2010 08:22 PM
2002 yz250 idles fine but bogs and tries to die when twisting the throttle (plz help! dobbs524 2-Stroke Dirt Bikes - Yamaha 19 05-05-2010 02:27 PM
