Old 03-07-2013, 05:46 PM
Last Online: 03-26-2013 10:28 AM
Default 2001 Honda Cr250 powervalve question after rebuild with pics
As some of you know i recently rebuild my 2001 honda cr250. Cylinder was welded, plated, honed, and surface ground by Millenium Technolgies. Weisco piston, plastics, clutch cable, yadda yadda ya, etc.
Whoever was the last person inside the engine didnt put the powervalve back correctly and the shaft that the powervalve pivots on was completely missing, and this piece (shown below) was broken.
I didnt see this piece in any sort of manual or anything online, so i put it back together without it.
Now, the bike runs great, but it will not hit the powerband
The valve is adjusted correctly, underneath the bolt on the right side of the engine, the slot it properly alligned at "L" when the bike is idling, when i rev the bike up, it does not flutter or move whatsoever.
Anybody have any ideas???
Heres a few pics of the bike:
Old 03-07-2013, 06:43 PM
dogger315's Avatar
and this piece was broken...so i put it back together without it
I don't know where to start. You are missing parts of the PV assembly
and have found broken parts as well, and you decided it was OK to run
without them?
I'm assuming you are leaving part of the story out. Like the part where
you took the PV assembly out and checked and cleaned each and every
component, replacing anything missing. Then you went over the PV
cavity and the rest of the cylinder scouring to find out what broke and if
there was anymore carnage laying around just waiting to trash your new
top end. Then, once satisfied you covered everything, you put it all back
together and installed and set it up per the manual, and now don't under
stand why the PV is not working, right?
If all the above is correct, the most frequent problem is failure to properly
engage the crowfoot at the base of the cylinder. As far as the broken part,
hard to tell without cleaning up the debris and providing some sort of scale
in the picture.
dogger
Old 03-07-2013, 06:46 PM
Last Online: Yesterday 10:52 AM
So you have all the parts in this picture?
OEM Parts and OEM Motorcycle Parts for Dirt Bikes, ATVs and UTVs | Rocky Mountain ATV/MC
If so, your problem may be with the power valve governer located behind the right case cover.
Old 03-07-2013, 10:35 PM
without them?
in the picture.
dogger
The powervalve assy. was completely degreased with oven cleaner prior to installation. I did replace the missing shaft with a new one, and i checked the old one to make sure it was in spec. Forgot to include that, sorry.
As far as the crows foot goes, im about 99% sure that it was installed correctly. If i were to pull the jug back off and check to make sure that the two pieces are mated correctly, i would most definately need to use a new base gasket, correct?
I seem to have misplaced the broken part, but if i recall correctly, it was around the size of a nickel.
One more note, when the jug was off it didnt seem that the prong that comes off of the govenor shaft that comes out of the engine that the crows foot mates too, seemed like it was in the middle of it travel. Rather than one way or the other... Which also wouldnt make sense because then the PV would be halfway open, if it were adjusted properly.
Basically if i pull it back apart, and the crowns foot was installed properly, then there is an issue with the govenor inside the engine underneath the right side cover.
Do you need to split cases to replace the govenor?
---------- Post added at 09:35 PM ---------- Previous post was at 09:33 PM ----------
Yes i do believe i have everything installed in the pic
Old 03-08-2013, 02:59 AM
You don't split cases to get to the governer. Just behind right side cover. I would use new gaskets for the repair.
Old 03-08-2013, 08:13 AM
VAL's Avatar
VAL VAL is offline
Last Online: 03-28-2018 10:50 AM
I think my basic question would be, where did you find the broken part? In the exhaust port, in the left inspection port, in the right side valve linkage cavity?
Old 03-08-2013, 10:17 AM
bjunior's Avatar
novice
Last Online: Today 11:08 AM
u need a manual, it will tell u every thing about the power valve, oem r the best. i was having trouble with my power valve
after countless times of taking it apart . i torque the two bolts down then worked like a champ.
Old 03-08-2013, 10:37 AM
you can take the cover off the left and or the right side and see if your powre valve is moving as the revs go up if you want to check that before tearing it down again. when the engine is not running the actuator porition down in the lower right side (the pin the crows foot goes on) would be in the closed position. was it free to turn from side to side etc when you put it back together?
Old 03-08-2013, 11:57 AM
dogger315's Avatar
I think we're on to something with this statement. If the pinion
shaft is engaged with the governor correctly, the pin should be
parked to one side (see picture) allowing full throw when activated.
Left side of picture is front of engine:
This is a simple fix. Remove the cylinder, remove the case cover
and pull the pinion shaft up to disengage it from the governor, then
turn it to orient it like the above picture and push it back in place.
re-assemble everything with careful attention to engaging the crow
foot to the pinion pin correctly.
Since that broken part in the picture was covered in carbon, I'm guessing
it came from the PV cavity. Here is a picture of what that cavity should
look like if everything is intact for comparison.
dogger
Old 03-12-2013, 09:40 PM
dogger
Pulled the jug up, but not off completely tonight. Some things i noticed:
The pinion shaft which comes out of the engine has the ability to move back and forth about 45 degrees, it can also pull right out.
Also i noticed some slight scoring on the exhaust side of the piston. I know i cleaned the jug 4 times before installation, same with the piston, and i also know the oil/fuel ratio at 32:1. The bike also has a new air filter.I broke the bike in by starting it up and letting it idle for 10 mins, then letting it cool completely, then several 5-10 min rides with slightly more throttle each time. The plug is dark, but not black.
I ordered all the required gaskets, water pump, right side cover, base gasket, etc.
Im going to tear the bike down more tommorow, and ill write back with my findings.
Thanks for all the help, i really appreciate it (especially dogger)
-Chris
Old 03-13-2013, 07:55 PM
Pulled the side cover off just now, the govenor looks to be in good shape, nothing noticeably broken/damaged/worn out.
Now, when i hold the governor and rack assy down by hand, the pinion has no play, i put the right side cover back on, and the play in the pinion persists... what gives??
am i installing it incorrectly?
Old 03-14-2013, 06:56 AM
Last Online: 02-20-2016 01:21 PM
Noticed you said scoring on the exhaust side.
Did you drill your piston so oil can cool off the exhaust bridge?
Old 03-14-2013, 10:03 AM
dogger315's Avatar
Tough to diagnose a problem over the internet, especially without pictures
or video of what you are doing.
For troubleshooting, you should leave the right side case cover off until
you have determined everything works correctly. Now it's a process of
functional checks and elimination.
Set the pinion shaft up in the case so that it's oriented correctly. Now try to
move it by hand (it shouldn't move). Make sure the pinion shaft bushing is
installed. Next, do the same with the cylinder. You should be able to open
and close the PV by hand. Verify this by watching the flap and two rotory
valves move when you rotate the linkage back and forth. Now make sure
you can't move the assembly if you hold the crowfoot - this test to make
sure the pinion lever is tight on the shaft. Also, there shouldn't be any up
or down play evident. Finally, make sure the upper pinion shaft bushing is
installed.
If all these test work correctly, and there is nothing else amiss from your
visual inspection of the PV cavity and the area around the flap valve, and
assuming the governor is not bad, the PV should work correctly.
PV are like automatic transmissions. They look complicated, but are really
straight forward and easily serviced as long as you work slow and steady
with strict attention to detail.
dogger
Old 03-14-2013, 10:18 AM
VAL's Avatar
VAL VAL is offline
Originally Posted by DBShred View Post
Bearing shield on either the right or left valve.....
Old 03-14-2013, 09:47 PM
Last Online: 02-06-2014 09:09 AM
have a look at this pic Honda East Toledos' 2001 Honda CR250R Parts Image
make sure you have both washer spacers (#19) on the governor shaft... if one is missing and you put the case cover on, there will be too much play between the case covers and the shoulders on the governor shaft, which will allow for radial travel of the whole mechanism, resulting in movement of the crowsfoot.. Because the governor is a pinion drive system, it needs to be snug betwen the cases for no movement, and remember that Honda also accounts for the thickness of the gasket material when calculating the clearance tolerances for that governor shaft!! hope this solves your end play problem..
Old 03-14-2013, 11:54 PM
Okay guys, ive made some headway!
I realized that the crows foot and pinion were not lined up properly, i actually bent the crows foot , so ill need to order one of those, yay more money!!
Looking at several other threads all over the internet, the play in the governor shaft is normal. I assembled the top end back together, being super careful to allign the crows foot and pinion. With the right side cover still off i checked to make sure that they were properly mated.
I then reinstalled the right side cover.
I still need to adjust the powervalve, from what i understand, i need to turn the crows foot shaft all the way counter clockwise(until the play is gone), while holding the valve all the way in the "L" postition.
Im going to refill it with coolant and trans oil tomorrow, and HOPEFULLY the powervalve opens all the way from L to H.
Just to clarify, the broken piece i was asking about before, was the side to one of the bearings.
Also, it should open from L to H, just by revving it in neutral, correct?
Thanks again guys!
---------- Post added at 09:54 PM ---------- Previous post was at 09:49 PM ----------
I didnt drill anything.
While everything was apart, i checked the cylinder, there is no scoring, just slight marks, which is weird, i have ridden the bike for maybe 1-2 hours tops, it loooked worse when i was looking up through the exhaust port, and it was covered in oil.
I compression tested the bike, i got an even 170 psi, which i assume is normal. Its a matco gauge (expensive piece, lol) so i believe it is quite accurate.
The bike has a ton of low end power, more than ive ever felt on a 2 stroke before, hopefully the high end power impresses me just as much (if i can ever figure this damned thing out lol)
Old 03-15-2013, 02:43 AM
JMV's Avatar
JMV JMV is offline
Last Online: 02-04-2018 12:19 AM
Yes, that's correct. When the engine spins high enough RPM, the balls in the governor overcome spring force and open the power valve. Doesn't need to be in gear for this.
Old 03-15-2013, 03:50 AM
Last Online: 02-07-2017 06:21 PM
The '01 CR250 doesn't have an exhaust bridge...there is one on the '01 CR500 though.
I have to agree with VAL it does look like a bearing shield.
Old 03-15-2013, 08:34 PM
JMV's Avatar
JMV JMV is offline
There is only one bearing in the powervalve assy and it's on the right side of the cylinder where the governor attaches. that bearing is open on both sides (no shield). Edit: Oops I take that back. Looked at the microfiche for 2001. My 92 has a bushing on the left side, but the 2001 does have a ball bearing and it appears to have a shield.
JMV
Old 03-17-2013, 09:08 AM
The powervalve works!!!!
The bike runs pretty damn good, i went to a small track yesterday, and put a few hours on the bike.
I feel like it SHOULD have a little bit more power than it does, low end is gnarly, but it still feels like its missing some pop in the top end. I know the powervalve is opening completely.
Question: is it possible for a motor to be ported, but for low end power?
Also, the bike runs pretty good, a tad bit rich if anything, would leaning it out help with the power.
Thanks!
Similar Threads for: 2001 Honda Cr250 powervalve question after rebuild with pics
1996 honda cr250 Resto/ Rebuild/ update livetoride21 Dirt Bike Restorations and Builds 35 04-21-2014 10:47 PM
top end rebuild honda cr250 1998 supermoto Dimmy 2-Stroke Dirt Bikes - Honda 7 01-09-2013 08:30 AM
Rebuild of my 1998 Honda CR250 BlackCR25098 2-Stroke Dirt Bikes - Honda 27 01-06-2012 08:05 PM
2001 CR250 Rebuild travisxr50 2-Stroke Dirt Bike Forums 11 02-02-2011 08:43 AM
2001 kx65 shock rebuild question tonka Dirt Bike Suspension Tuning 3 11-29-2007 06:39 PM
