Old 05-16-2011, 12:31 PM
flashcr's Avatar
Last Online: 05-20-2014 11:05 AM
Default 2001 honda cr250 power valve
question , what if the line on the exhaust shaft is not line right up with the "L" mark ? is there a way to make the adjustment with out ripping everything apart?my bike was bogging a little at low rpm,but at home when i cracked the throttle it did move to the "h" mark and sounded fine, thanks for any answers.
Old 05-16-2011, 12:51 PM
Last Online: 03-16-2015 10:47 PM
If you have a manual it will show you how to adj.the linkage. Realize of course if you didn't fiddle with it before it probably did not change. It may be time for a cleaning.
Old 05-16-2011, 01:21 PM
flashcr's Avatar
thanks, yeah i have never adjusted it or played with it, so i guess its time for a cleaning or try the adjustment route, thanks for the response.
Old 05-17-2011, 09:53 AM
beont's Avatar
Last Online: 09-25-2011 04:52 AM
gloves and start cleaning.
Old 05-19-2011, 03:32 PM
mynewcr250's Avatar
Last Online: 11-30-2018 06:23 PM
remove the exhaust valve cover, loosen the linkage rod bolt and turn the exhaust valve counter clockwise and clockwise and check for ease of movement . if it moves freely then I'd wait on cleaning it until you do a top end since you have to pull the cylinder to do so.
adjust the linkage by turning it completely counter clockwise until its lined up with the l mark turn the top linkage rod clockwise (looking from the top) and tighten the bolt back up. recheck for proper operation afterwards.
if you can't rotate it freely byhand when its loose you will need to clean it.
Old 05-20-2011, 08:00 AM
flashcr's Avatar
thanks guys, yeah i opened the right side cover made a small adjustment,checked the left small opening, still not dead center with the |L mark,but closer then before,started it last night,sits normal when running, and when throttle cranked it opend to the |H mark properly, guess i really wont know till the bike is under load.
Old 05-24-2011, 11:12 PM
mynewcr250's Avatar
you got a picture of it? both my 2000 and my friends 2001 do not line up perfectly with the l L mark, the actually seem to lean more to the actual L instead of the l. no matter how i adjusted it. when running it flutters ever so slightly at the l mark, so i think this play is intended especially if youre looking at it with the engine off.
Old 05-27-2011, 09:12 PM
flashcr's Avatar
soory for the dealy in getting back to you,sorry no picture yet, tomorrow i will get one, mine looks like its sitting like yours, had it out this afternoon, seems to be bogging now, i dont know, cant wait for the rebuild.
Similar Threads for: 2001 honda cr250 power valve
power-valve help on 91 cr250 puggerton03 2-Stroke Dirt Bikes - Honda 0 07-21-2010 05:39 PM
2001 cr250 power valve help 1motoman69 2-Stroke Dirt Bikes - Honda 1 07-04-2009 09:41 AM
2001 cr250 power valve adjustment hardcore 2-Stroke Dirt Bikes - Honda 12 06-04-2009 10:06 PM
98 cr250 power valve?????? larensdad 2-Stroke Dirt Bikes - Honda 5 10-02-2008 01:57 PM
2001 RM 125 Power valve discussion Lane 2-Stroke Dirt Bikes - Suzuki 4 07-11-2007 10:14 PM
