Old 05-15-2011, 09:12 PM
Last Online: 05-22-2011 08:45 PM
Default 2001 honda cr125 not starting leaking head gasket
hey guy i just bought this bike about a week ago i went out for a ride about an hour later it shut off just bogged out. I got new plug an cleaned out teh carb an airfilter i tried to kick start it wouldnt kick over so i rolled start it it started right up i let it idle for a bit then shut it off an it kicked over again let it idle for a couple mins i noticed a little white smoke so i shut it off let it cool down then i did a coolan change i drained out the old coolant which was to much in there an it was a nasty yellowish color so i changed the coolant did everything the way the service manual tells you to do it went to start it up as i was kicking it i felt a slight spray on my leg i looked down an i noticed that it was leaking out of the head gasket.. i looked through the service manual it says it could be a couple different things but it doent really go into detail. i was wondering what you guys thought any help/ advice/ things i should do would be awesome i just want to get this bike running right so i can get out an ride
thanks
drew
Old 05-16-2011, 03:42 PM
Last Online: 06-05-2011 12:34 PM
if i was you i would order a top end gasket kit, pull the cylinder head off, check for damage to both surfaces where the head gasket seals (on the barrel and head), if its ok, clean it up, replace head and base gaskets, then put it back together and see how it works.
Old 05-16-2011, 05:28 PM
Ok thanks makita. What's a good brand for gasket kits or should I just go OEM? I was looking on a couple sites an ready customer reviews an it was 50/50 some said they had to fabricate an some didn't come with all the pieces it was supposed to come with.. What's your take on gaskets?
Old 05-16-2011, 08:26 PM
bbrmotosports's Avatar
Rockin A class
If your going that far as to replace all the upper end gaskets you might as well put a top end in it considering you just bought it not knowing how much time is on it. Just my 0.02
Old 05-17-2011, 01:59 AM
so i took apart the bike drained all the coolant an gas. toook the head off took the expansion chamber off an there was a **** load of fluid in there. then i took off the cylinder is there supposed to be fluid still in there? im trying to post some pics
Old 05-17-2011, 03:18 AM
beont's Avatar
Last Online: 09-25-2011 03:52 AM
Nope. seems like the top end metal gasket or the screws are loose on the cylinder. try to tighten up with 2 nuts an the same screw
Old 05-22-2011, 03:37 PM
this is driving me crazy i did a whole new top exactly the way it tells you in service manual.. i go to start it up an nothing still wont start.. i cant figure out what to do to get this thing running
---------- Post added at 04:18 PM ---------- Previous post was at 04:02 PM ----------
actually got it to kick ovwer a few times but it doesnt stay running just cuts right out
---------- Post added at 05:37 PM ---------- Previous post was at 04:18 PM ----------
got it running finally an its running good just need to tune it a bit
Similar Threads for: 2001 honda cr125 not starting leaking head gasket
1987 honda cr125 starting problem, more problems Duncan4ever 2-Stroke Dirt Bikes - Honda 2 04-04-2011 07:58 PM
honda cr125 motor not starting tracyconnor 2-Stroke Dirt Bikes - Honda 5 06-24-2010 02:54 PM
2001 CR 125 New head and gasket? naggus 2-Stroke Dirt Bikes - Honda 0 10-14-2008 08:11 PM
2001 CR125 starting hard guytimes 2-Stroke Dirt Bikes - Honda 8 03-13-2007 03:32 PM
LEAKING HEAD GASKET!!! senatesk8r216 2-Stroke Dirt Bikes - Honda 12 03-29-2004 09:13 PM
