2001 CR250R shock options
This is a discussion on 2001 CR250R shock options within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; I have an '01 CR that I love dearly. I ride both MX and off road and would like to ...
Old 10-24-2009, 10:44 PM
Last Online: 11-11-2009 09:17 AM
Default 2001 CR250R shock options
I have an '01 CR that I love dearly. I ride both MX and off road and would like to pick up a second shock so I can leave one setup for MX and the other off road. Also would be nice to have one to use while the other is out for servicing and such.
I'd like to buy the newest that will fit to improve chances of it being fairly fresh and I believe honda has reduced stiction and such over the years (perhaps even a new one off ebay). I'm not worried too much about spring rate and valving as I'll set both of those up to suit my conditions etc. If anyone knows what years and models (CRFs?) would be a direct fit (if any) other than 00-01's that'd be great!
Here's a pic of the CR for good measure
Old 11-02-2009, 02:46 PM
Bump - anyone have any info on this?
Old 11-02-2009, 03:42 PM
dogger315's Avatar
Last Online: Today 11:05 AM
Unfortunately none of the later model CR or CRF shocks are a direct swap.
The clevis is longer starting in '02 for the CRs and all the CRFs are in-
compatible as well. The only shocks that will work on your '01 without
modification are the '97-'01.
By the way, I share your enthusiasm for the '01 CR, the best ever motor
with a decent frame and suspension. Stock, it's superior to any later CR.
I'm enclosing a picture of the shock from my '02 so you can see the clevis.
dogger
Old 11-02-2009, 07:53 PM
Thanks! Just to be sure I'm on the right page, the Clevis is the aluminum part of the shock that the lower shock bolt would pass though (and where the rebound damping adjuster resides) - correct? Is the clevis the only part that differs? Can it be swapped or modified to work?
Thanks again!
Josh
Old 11-03-2009, 03:19 PM
dogger315's Avatar
Correct. On a stock shock, the clevis is integral to the shock shaft.
To swap shock shafts, just keep the brand the same (Showa or Kayaba)
as the shock you plan to use and you should be able to purchase what
you need from Honda.
In other words, if your '01 is equipped with a Kayaba shock, you can purchace
a new '01 shock shaft and install it into an '06 Kayaba shock to get the
correct clevis for your application.
If you decide to use an aftermarket shock, some allow you to replace just
the clevis.
dogger
Old 11-10-2009, 10:34 AM
Thanks!
Similar Threads for: 2001 CR250R shock options
2001 cr250R for sale 713moto Motorcycles & ATV's 0 04-10-2008 05:43 AM
2001 kx65 shock rebuild question tonka Motorcycle Suspension Tuning 3 11-29-2007 07:39 PM
Hello.....new here and new proud owner of a 2001 Honda CR250R. :) CableTec Member Introductions 18 04-04-2007 12:01 PM
OPTIONS OPTIONS OPTIONS???? TRXman86 General Discussion 11 02-08-2006 05:52 AM
Considering options Noobrider ATV/UTV - General Discussion 18 12-03-2004 02:13 AM
