Old 02-21-2010, 12:38 PM
Last Online: 08-24-2012 03:31 PM
Default 2001 cr250 crank length problem?
Hello, I am in the process of rebuilding the bottom end of my 2001 cr250. I have a new wiseco crankshaft in and the cases are back together.
I am about to put the primary drive gear on the crank and it seems that the crank itself is too long... when i snug up the bolt and washer there is about 0.2mm of play in the gear. is this normal?
I cant see how this could be happening due to any error in assembly. I took some measurements of the old crank and it seems to be shorter by about 1.2mm
I'm thinking of putting a shim between the existing nut/washer and the gear since this should not effect the alignment with the clutch basket gear.
It is a wiseco crank kit for CR250's from 92-01. Maybe someone else here has encountered this problem or has some insight.
Thanks
Similar Threads for: 2001 cr250 crank length problem?
CR250 Crank crguy 2-Stroke Dirt Bikes - Honda 9 04-03-2011 01:58 PM
2001 yz125 crank shaft HEAVY HITTER 2-Stroke Dirt Bikes - Yamaha 5 07-13-2008 04:06 PM
yz250 crank problem yzfever 2-Stroke Dirt Bikes - Yamaha 23 04-12-2008 03:34 AM
2001 cr250 kickstart problem.......... 713moto 2-Stroke Dirt Bikes - Honda 4 10-19-2007 11:12 PM
1992 cr250r crank seal problem cooperstevens 2-Stroke Dirt Bikes - Honda 4 03-30-2007 01:10 AM
