2001 CR250 carb sucksThis is a discussion on 2001 CR250 carb sucks within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; Dogger thanks for the link. Heres one you might find usefull, a memeber from another site had both the S66 ... |
#41
#42
| Thanks, good info and an excellent baseline to start from for jetting. dogger |
#43
| Quote: |
#44
| Before you mount the intake, could you take a picture of the modified side for avi-b so he can see what it's supposed to look like. I would do it but I already mounted mine and would have to replace the gaskets if I took it apart again. Quote:
I don't have the patience to wrestle with the carb boot in such tight conditions. I mount the carb, install the throttle cable, route all the vents, spray some silicon lube on the intake bell and rubber boot to help ease the install when reattaching the subframe. dogger |
#45
| Sorry man,i have already installed it Here is a link to cutting the stuffers from the boot V Force Delta 2 Reed Valve Install Last edited by bundyho1; 07-12-2009 at 09:57 PM. |
#46
Fine tuning the jetting should be a piece of cake now. dogger |
#47
As for the measurement, I found what I was looking for. Overall inlet to outlet. 01'-03' CR 250 TMX = 86mm 04'-07' CR 250 TMX = 75mm One thing to keep in mind when trying to make a different carb fit in the existing space is the use of reed spacers or maybe even the V-force. I noticed in doggers final installment of the CR motor build he starts with the stock reed cage but ends with a V-force. It looks to be quite a bit thicker than the stock cage in the picture. Dogger can you measure the difference? |
#48
reed cage install rather than the VForce. Quote:
flange and extra gasket total 12mm. dogger |
#49
| one thing i noticed even with the new 2000 carb insulator the card doesnt completely fit in the air box boot all the way.(cr250-2001)i also have vforce3 reeds also i found this link [Only registered and activated users can see links. ] OK here is my settings 45 pilot a 1370DKA needle on the 2nd clip with a 178 main.running really good at 80temp with 50% humidity .900feet abouve sea level Last edited by bundyho1; 07-15-2009 at 02:10 PM. |
#50
| Quote: |
#51
| Well i tried the 42 pilot first an it was on the lean side ,high idle so i tried the 45 and now she purrs like a kitten |
#52
| O.K. I've been reading this thread and I still haven't found the answer. Did the 2000 CR250 come with the Keihin 38mm airstryker?? |
#53
dogger |
#54
| Another + to this has been the gas mileage it doesnt burn half as much gas as it used to.I have noticed that it loads up really fast when you putt around even after the carb swap but it is alot better. |
#55
#56
| ok, i have been reding this thread. i have a 98 yz250 that has the pwm carb, i dont care for it. i want to mount a pwk. back earlier in the thread, there was a part# one of you guys supplied and pic of a new carb in a bag. i need the shorter more compact bodied carb. the 75mm version. is that honda part# what i am after? i would buy one of the tomorrow if i knew it was the carb i am looking for. i need the 75mm body and a 38mm carb. hoping finding this new board will help me get that PWM carb outta my life! |
#57
PWK has the shortened body. You might try PMing YZhallsme and asking, he was the one that had that info. dogger |
#58
| had to leave him a visitor message as i dont think i have the post yet to pm someone. hope to hear from him soon as i cant wait to ditch this pkm carb |
#59
#60
| just doesnt carb well at low speed from what i have exp so far. plus i hare scramble and enduro and the pwk gets better fuel mileage. |
| Tags |
| cr250, keihn, pwk |
| 2000-2001 CR250 Rear end on 1997 CR250 | Caseys500 | 2-Stroke Motorcycles - Honda | 0 | 08-22-2007 06:46 PM |
| will a cr250 2000-2001 carb fit on my 96cr 250? | cr250freak | 2-Stroke Motorcycles - Honda | 7 | 01-20-2007 06:11 PM |
| can i put a 2001 yz carb on 03 cr 250? | doghenry2321 | 2-Stroke Motorcycles - Honda | 11 | 01-07-2007 03:42 PM |
| 2001 CR250 carb/jetting problems | ryancr500 | 2-Stroke Motorcycles - Honda | 24 | 08-30-2006 12:52 PM |
| 2001 CR250 Carb tuning Help!!! | e4dragongunner1 | 2-Stroke Motorcycles - Honda | 5 | 04-15-2005 05:11 PM |
