2001 CR250 carb sucksThis is a discussion on 2001 CR250 carb sucks within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; The new style uses a top retained by 2 screws
The version you are talking about is a Keihin PWK ... |
#21
These use the PWK basic features like the semi D slide with the air strykers, but the rest of the carb is heavily modified to suit a particular application. Kawasaki, Suzuki, Yamaha and even KTM all used this version that features a throttle position sensor, electronic power valve and modified cap. This is a very trick carb with a very trick price (retailing for almost half what bundyho1 paid for his bike). Honda was the loan user of the Mikuni TMX and paid the price. It was like Honda hired a bunch of idiots to ruin their two stroke program - Case reeds, electronic power valves, "boat anchor" crankshafts, Mikuni TMXs. The list is long and ridiculous. You can get a similar version of this carb called the PWM which is available without the electronics and would make a killer carb for any 250. dogger Last edited by dogger315; 06-27-2009 at 03:42 PM. |
#22
| Quote: ---------- Post added at 05:44 PM ---------- Previous post was at 05:36 PM ---------- Quote:
#23
I think KTM's only use of a PWK power jet carb was on the 2000 SX. Heres a link to the PWK used on most of KTM's 2strokes today, no electronics. http://65.57.254.60/shoponline/catal...85033111%2Egif If you look around you'll find you can get a new 38mm version of this carb for @ $250. Quote:
bundyho1 I think it's a good thing that you have the older style PWK as I'm afraid you might have trouble trying to get a newer style to fit. It looks to me like the newer PWK is a good 13mm shorter than our CR Mikuni's. |
#24
| YZhallsme and bundyho1, I don't want to beat this to death, but Just to clear up some misconceptions, I submit the following: Here is a picture from the Keihin website of the PWK quad vent air striker. ![]() It has a screw-on cap, is 91mm from front to back and has a modified D slide with bat wings. The carburetor shown in the exploded parts diagram you listed IS a PWK by virtue of the slide design and the separate idle circuit. But it is also a "boutique" (specially made to a manufacturer's specifications) carburetor. The carb body, cap, dimensions and electronics are all unique to that version for that application. There are no early or late model PWKs. If you ordered the latest model of PWK from Keihin or Sudco, you would get a carb that looks just like the one in the picture. Any other PWK is a specialty version manufactured by Keihin to an OEs specifications. Quote:
of the powerband. For instance, a 91 mm PWK will have better low to mid than a 75mm PWM which will be more mid and up. Unless you know what you are doing, I wouldn't recommend altering any of your carb dimensions. Just replace like with like, size wise Quote:
The PWK on the other hand, is 15 mm longer than the TMX, which is why many comment on the difficulty of stuffing a PWK into their TMX equipped bikes. On the plus side, the PJ that the steel framed CRs came with is 91mm from spigot to bell just like the PWK. Which means I will have no trouble substituting a "striker" for the PJ on my '93 resto. dogger |
#25
| really good info,i will update when i get the pwk carb installed. |
#26
| dogger315 I think it's important that those reading this or considering a change to a PWK carb understand that there are variations of the PWK carb. Yes there are PWK's that are made for the O.E.M.'s and they are made to the manufacturers specs, they can and do differ from the aftermarket versions offered from Keihin, those differences can be minor (00' cr 250) or huge (03' YZ 250). My guess is that most (not all), will look to E-bay or a similar source for a used carb and there they can find any of the variations produced to date, most likely though all will be refered to as simply "a 38mm PWK". Even today the aftermarket PWK offered from Keihin appears to be available in 2 variations. The standard 38mm PWK = part# 71R, and the Quadvents/Airstriker 38mm PWK = part# S66. [Only registered and activated users can see links. ] bundyho1 I'm still unclear as to which version of the PWK your getting, I understand it's an airstriker but is it the aftermarket S66 or one from an O.E.M.? At any rate I wish you well and look forward to hearing how it works out. |
#27
| here is the one i got ebay Item number: 320385691952 i had a coupon and didnt pay that much man i hope its not too hard to fit in there. ---------- Post added at 09:57 PM ---------- Previous post was at 09:46 PM ---------- Quote:
#28
page here. Quote:
is where you spend most of your time. Unless you are an A class (expert or pro) you won't even notice, much less miss the change. Quote:
so substituting a '00 carb insulator for an '01 would compensate for the additional carb depth. The Honda part number for the insulator you need is 16221-KZ3-J20. The reed valve is the same for both years. We're only talking 3/4" here, but the fit is tight already so this change would definitely make life easier. Quote:
is less tempermental and I think it will be beneficial in that it will allow you to ride and have fun on your CR instead of constantly screwing with the jetting as the temperature and humidity change. By the way, I was wrong, you don't have to change the throttle cable. dogger Last edited by dogger315; 07-02-2009 at 01:44 PM. |
#29
| OK i priced the carb insulator and its 50+$.Im wondering what do you all think of the boyesen rad valve.I have seen them for 129$.I might as well get reeds for it too i guess.THey are the stock ones in there.I wonder how well they work with the cr250 ? |
#30
| I still recommend the VForce over the Boyesen. I have used both and both are an improvement over stock, but the VForce is superior to the Boyesen. The one on Ebay is 5% off for a total of $114 and free shipping from Trinity Racing. Got mine two days after I bought it. Here is the Ebay item number: 260398261088 By the way, the 5% off ends tomorrow. Better Reed for less money, sounds like an easy choice. dogger |
#31
| hey dogger do i need to buy the clamp that goes with the INSULATOR, or does the 2001 one work?Just want to know before i get one soon.. |
#32
| No problem using your OE clamp. Here is a picture of my new-in-the-bag Keihin PWK quad vent air striker. Pre-jetted, float level already set and ready to bolt on for $168 from Honda. I can't believe what a good deal it is! You can't buy a lousy PJ for under $200 from Honda. I am going to buy a few more to have for spares and use on other projects at this price. By the way, I did a little research and found out the only CR that came with this carburetor was the 2000 250. Prior years came with non air striker PWKs or PJs and subsequent years came equipped with the TMX. dogger |
#33
| yea that is a great deal.Im wondering what Pre-jetted settings is on the carb?the 2000 model jetting?Well i went ahead and got those reeds(v-force).Now do i have to cut the 00 carb insulator when it gets here to fit the reeds in?Thanks Last edited by bundyho1; 07-04-2009 at 12:32 PM. |
#34
Dogger I've been told the 99' carb was a PWK airstriker also but don't know for sure! The 00' needles are triple taper needles. The first 3 numbers in the needle number relates to the needles straight diameter, the stock A715 then = 2.715mm. They are available in .10mm increments from 2.685 thru 2.745. In the parts fiche they show another set of needles with the same diameters but the second set of 3 digitis is 294R instead of 289R. I think these needles are the same except for a 1/2 clip position. Don't know if they are richer or leaner, they aren't mentioned in the service manual. |
#35
exploded parts diagram for both carburetors. If you look at the slide in the first diagram, you'll notice it is a straight up D-slide with no "bat wings". This indicates the carburetor is a non air striker PWK. It is also listed as a PWK00A A in the parts description which corresponds to a normal PWK quad vent. Now look at the slide in the '00 carb diagram. The "bat wings" are present so this carb is an air striker PWK. Honda used a PJ28LA with throttle position sensor and power jet in 97 and 98, which was a bust. Then switched to Mikuni and the TMX in '02 and stuck with that until CR production stopped, leaving '00 as the only year the Air Striker made an appearance on the CR. dogger ![]() |
#36
1=standard PWK (no vanes), available from Keihin and the O.E.M.'s 2= PWK Air striker (vanes), available from Keihin and the O.E.M.'s 3= PWK Air striker with shortened body (my 03' measures 75mm), available from the O.E.M.'s. Used on YZ, KX and RM 250's since @ 00' and by KTM since @ 04'. Quote:
B-The square or match box shaped one used on the 01' to 03' CR 250 [Only registered and activated users can see links. ] And C the curved one used on the 04' to 07' CR 250 [Only registered and activated users can see links. ]. Last edited by YZhallsme; 07-05-2009 at 02:43 PM. |
#37
| Thanks for the "schooling". I see the vanes cast into the inlet bell. Learn something everyday. I went back and looked at some additional resources after reading your post and finally found one that included a description of the '99 carb. According to this source the '99 carb is the same as the '00 carb, both are PWK 38 quad vent air strikers. You are absolutely right and I stand corrected. I really appreciate this "refresher" on carburetor identification. Cleared up some misconceptions and I picked up some useful information - what more could you ask for. dogger |
#38
| Ok i have most of my parts in and will be installing and testing it out the next few days.I have been doing alot of reading on this and i have the stock 99 jet needle and the ddk one to play with.Im at about 900ft above sea level and from what i have read im going to start out with a 178 main and a 42 pilot.needle clip in the 2nd p. weather now is in the 80s.So what do you guys think? |
#39
---------- Post added at 08:23 PM ---------- Previous post was at 06:53 PM ---------- Quote:
The cutaway will have an effect early in the throttle range. See the graph and #7 [Only registered and activated users can see links. ] Over the last two years I've read many many threads about this. I can't recall anyone (zero, zippo, nada) ever going back to the Mikuni! |
#40
![]() Quote:
Navigate to the specific model you are interested in, and scroll down to the section marked serial numbers. The site contains lots of useful information and is a "goldmine" for rare vintage parts - for a price. dogger |
| Tags |
| cr250, keihn, pwk |
| 2000-2001 CR250 Rear end on 1997 CR250 | Caseys500 | 2-Stroke Motorcycles - Honda | 0 | 08-22-2007 06:46 PM |
| will a cr250 2000-2001 carb fit on my 96cr 250? | cr250freak | 2-Stroke Motorcycles - Honda | 7 | 01-20-2007 06:11 PM |
| can i put a 2001 yz carb on 03 cr 250? | doghenry2321 | 2-Stroke Motorcycles - Honda | 11 | 01-07-2007 03:42 PM |
| 2001 CR250 carb/jetting problems | ryancr500 | 2-Stroke Motorcycles - Honda | 24 | 08-30-2006 12:52 PM |
| 2001 CR250 Carb tuning Help!!! | e4dragongunner1 | 2-Stroke Motorcycles - Honda | 5 | 04-15-2005 05:11 PM |
