Old 01-10-2017, 03:27 AM
Last Online: 05-22-2018 12:45 PM
Originally Posted by byronk View Post
he means the forks, they are twin chamber on the 01 - check parts diagrams.
Whoops. Didn't realize they had twins on them in '01.
Old 01-10-2017, 08:27 AM
no worries, the 250's switched to twin chambers since 97 actually!
Old 01-10-2017, 09:59 AM
gusco's Avatar
Last Online: 05-21-2018 08:05 PM
Hit another big snag late last night/early this am: At some point the chain slider was allowed to wear out and the chain wore into the swingarm. It's just deep enought to have started touching the needle thrust bearing.
Old 01-10-2017, 11:08 AM
wow! a good welder could fill it up with aluminium weld and a bit of sanding work afterwards to get it proper to fit the slider and should be good to go.
tip, the welder should fill it up as is without the bearing removed.
Old 01-21-2017, 08:41 PM
gusco's Avatar
Parts finally showed up after there was some sort of mix up with RMATV. I decided to start on the swingarm stuff and work my way forward. The shock had never been serviced and so it was peened. I filed off the end of the shaft until the nut came out, but I made a BIG mistake trying to reuse the nut It started to strip the shaft. Luckily I caught it and stopped. Now I've got to see if I can get the threads fixed up at a shop (I don't have a tap and die set) in order to reassemble... that's what I get for rushing and not getting a new nut.
Old 01-24-2017, 08:40 AM
gusco's Avatar
Bottom end went together very smooth. Now I have to wait to have some time to finish up the top end. Shout out to Stevo for his hot-socket-in-the-inner-main-bearing-race-and-the-crank-slips-right-in technique and accompanying video
Old 01-24-2017, 12:34 PM
nice! would like to watch this video please.
Old 01-24-2017, 12:56 PM
gusco's Avatar
https://www.youtube.com/watch?v=NVp3sd2OyLM
Old 01-27-2017, 07:54 AM
gusco's Avatar
Hit another minor setback yesterday as I decided to advance on a few details while watching the kids play outside: The throttle cable (replacement was in original order) was seized to the housing. After some heat and PB blaster it came out. Also, the slide return spring was seized onto the cable holder/needle retainer because the nipple on it was not aligned to the slot in the holder/retainer. After pulling at it with a pick for a while it came loose, but then the holder/retainer was on WAY too tight and it collapsed in the slot area once torque was applied. I will have to order up a new one unless someone has a spare TMX laying around that they'd like to donate this part off of...
Old 01-28-2017, 11:30 PM
gusco's Avatar
Need help!: I went to check the bottom end before moving on to the top end this evening and found that I must have e done something wrong with the trans. It is stuck. Neither the input nor output shaft will spin. Any ideas?? I tried not to mess with the trans on disassembly, but must've either moved something or seized something up putting the cases back together.
---------- Post added at 12:30 AM ---------- Previous post was at 12:29 AM ----------
Also: the shifter won't move (up or down).
Old 01-29-2017, 06:31 AM
firstly try to remove the clutch cover and inspect the shift mechanism and if the clucth basket turns (main shaft). then if still nothing does not turn, unfortunately you have to split the cases.
Old 01-30-2017, 05:27 PM
gusco's Avatar
I didn't want to split the cases in case the gasket tore, but I got lucky and it stayed intact. Something hadn't sat right in one of the case halves because I just disassembled, made sure it was in N and reassembled and everything was fine. I also got the top end and power valve done today and got the motor in the frame.
Old 02-01-2017, 06:19 PM
gusco's Avatar
Mechanic cleaned up the shock shaft for me and it's ready to go get some nitrogen.
---------- Post added at 07:19 PM ---------- Previous post was at 05:42 PM ----------
Got a few pics up: http://s817.photobucket.com/user/bba...g.html?filters[user]=138274714&filters[recent]=1&sort=1&o=0
Old 02-02-2017, 07:36 AM
gusco's Avatar
[IMG]http://s817.photobucket.com/user/bballfreak21/media/IMG_20161231_021436036_zpstrv7leio.jpg.html?o=1[IMG]
[IMG]http://s817.photobucket.com/user/bballfreak21/media/IMG_20170105_222153666_zpsw8rhwgnc.jpg.html?o=1[IMG]
[IMG]http://s817.photobucket.com/user/bballfreak21/media/IMG_20170105_222205482_zps0kkbqhfz.jpg.html?o=1[IMG]
[IMG]http://s817.photobucket.com/user/bballfreak21/media/IMG_20170105_223154802_zpstyoyijni.jpg.html?o=1[IMG]
[IMG]http://s817.photobucket.com/user/bballfreak21/media/IMG_20170105_223231752_zpsvubzj7gi.jpg.html?o=1[IMG]
[IMG]http://s817.photobucket.com/user/bballfreak21/media/IMG_20170105_234924753_zpsr8bnu4pb.jpg.html?o=1[IMG]
[IMG]http://s817.photobucket.com/user/bballfreak21/media/IMG_20170106_241136246_zpsaz3zghhu.jpg.html?o=1[IMG]
[IMG]http://s817.photobucket.com/user/bballfreak21/media/IMG_20170110_240649929_zpsq36080he.jpg.html?o=1[IMG]
[IMG]http://s817.photobucket.com/user/bballfreak21/media/IMG_20170123_114921_zpshetuhadg.jpg.html?o=1[IMG]
[IMG]http://s817.photobucket.com/user/bballfreak21/media/IMG_20170130_132305_zpszpdovodo.jpg.html?o=1[IMG]
[IMG]http://s817.photobucket.com/user/bballfreak21/media/IMG_20170130_151112_zpsbnahiccv.jpg.html?o=1[IMG]
[IMG]http://s817.photobucket.com/user/bballfreak21/media/IMG_20170130_153849_zpskim0jjku.jpg.html?o=1[IMG]
[IMG]http://s817.photobucket.com/user/bballfreak21/media/IMG_20170130_154433_zpsvzllrd1a.jpg.html?o=1[IMG]
[IMG]http://s817.photobucket.com/user/bballfreak21/media/IMG_20170130_174310_zpslacatkjo.jpg.html?o=0[IMG]
Old 02-07-2017, 06:06 PM
Last Online: 02-07-2017 06:21 PM
I've got a TMX Parts Carb your welcome to. PM me if interested.
Old 02-07-2017, 09:12 PM
gusco's Avatar
Thank you! I sincerely appreciate it. The retainer came today in what I hope was my last order for this bike. If something doesn't work out I'll let you know.
Old 02-09-2017, 08:41 AM
gusco's Avatar
I got some work done on the bike late last night after the kids were put to bed. It's nearly assembled and needs the brakes bled. Hopefully she'll be fired up by this Saturday or Monday and ready to flip.
Old 02-10-2017, 08:28 AM
gusco's Avatar
Brakes got bled yesterday and I'm getting close to a fire-up. I don't like the way the rear rim looks though. It has a lot of dark spots. I hit it with a scotchbrite pad and wd40 and it did not improve. I then went on to steel wool and polish and still don't like it. Would it be too much to start at a 120 grit sand paper to clean it up and then move on up until polished?? The front wheel is polished, as is the frame. So, I either have to scuff up the front and rear to match or polish the rear to match. Thoughts??
Old 02-10-2017, 10:32 AM
87CRHon250's Avatar
Last Online: 05-15-2018 10:44 PM
"..I either have to scuff up the front and rear to match or polish the rear to match. Thoughts??.."
Pic it !
Old 02-10-2017, 10:33 AM
Last Online: Yesterday 04:20 AM
Honda Motorcycle Parts 2001 CR250R A CYLINDER HEAD Diagram
ServiceHonda.com - Motorcycle and ATV Parts, Accessories and more
or ebay? make sure to get the 1997-2001 studs (previous engines are shorter)
also check this guy out,
https://titanclassics.com/product/ho...um-head-studs/
maybe if you contact him he might make you a set out of Ti.
Just FYI Service Honda is out of business.
Similar Threads for: 2001 CR250
2001 CR250 $1,800.00 Wheaty316 Classified Ads 0 07-12-2008 11:46 AM
2001 CR250 HELP!?!?!?!?! 01Extreme69 2-Stroke Dirt Bikes - Honda 4 01-25-2008 02:53 PM
2001 cr250 leaper 2-Stroke Dirt Bikes - Honda 17 10-29-2007 12:38 AM
2000-2001 CR250 Rear end on 1997 CR250 Caseys500 2-Stroke Dirt Bikes - Honda 0 08-22-2007 05:46 PM
2001 CR250 FS/FT HONDA_PILOT24 Classified Ads 12 09-21-2004 08:13 AM
