![]() I was wondering, will the swingarm off a cr250 fit on a 2001 cr125? If so, do you guys know what year(s)? My freakin chain wore clear through the bottom of my swingarm pivot point to my bearings. DOH! ![]() |
![]() I don't think I would be mixing and matching parts. If you would like to do some research you can go to www.servicehonda.com and see if the part numbers for the swing arm match up to see if there is a possibility it might transfer. Sometimes this does no good as many of the part numbers will change even though the actual part does not, but it's worth a shot. Good luck. |
![]() You might be able to jimmy rig it...but I wouldn't recommend it. Bottom line, I would get a CR250 swing arm. |
![]() Cr125 p/n 52200-KZ4-J30 Cr250 p/n 52200-KZ4-J30 So I was wrong. They are the same swing arm. |
Thread Tools | |
Crack on 1996 cr250 swingarm | cr250scott | 2-Stroke Dirt Bikes - Honda | 1 | 03-30-2008 06:16 PM |
Seized Swingarm Bolt - 02 CR250 | in2cycles | 2-Stroke Dirt Bikes - Honda | 5 | 10-17-2007 08:26 PM |
CR250 03 Swingarm | Cragga37 | 2-Stroke Dirt Bikes - Honda | 4 | 09-02-2007 03:20 PM |
02-03 CR250 Possible Bent Swingarm | MOTOX024 | 2-Stroke Dirt Bikes - Honda | 2 | 03-24-2004 06:19 PM |
2001 cr 250 swingarm | Seanile27 | 2-Stroke Dirt Bikes - Honda | 10 | 03-10-2004 09:09 PM |
