2000 CR80 COOLANT LEAKING FROM OVERFLOW
This is a discussion on 2000 CR80 COOLANT LEAKING FROM OVERFLOW within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; I have a 2000 CR80bw that has a new 105 kit. I has been leaking coolant out the overflow on ...
Old 01-07-2007, 02:44 PM
Last Online: 02-19-2007 10:43 PM
Default 2000 CR80 COOLANT LEAKING FROM OVERFLOW
I have a 2000 CR80bw that has a new 105 kit. I has been leaking coolant out the overflow on reving, from the moment its started. I replaced the $35 radiator cap (rip off) and its still does it.
I was told it may be the cyl. head gasket. . . any comments??
Ps I've done all the usual checking.
I have a CR500Dualsport, LT500, TRX250r, CR80, CR105, (2) LT80s.
Old 01-07-2007, 03:53 PM
vintageguy's Avatar
Keep them going....FOREVER
Last Online: 02-21-2010 07:29 PM
Default Re: 2000 CR80 COOLANT LEAKING FROM OVERFLOW
Yes it might be the head gasket, a friend of mine has a 1990 RM80 that had the same problem it was the head gasket, although it might just be to much for the coolant system with the 105 kit.........
Old 01-07-2007, 08:57 PM
FFRacing11x's Avatar
The "ONLY" FastForward
Last Online: 03-07-2010 12:20 AM
Head gasket leakage was a problem with the stocker that only got worse with the big bores. I have heads for sale that are Oringed to alleviate this problem. Tdub
Old 01-17-2007, 07:42 AM
jason33's Avatar
Last Online: 01-06-2008 08:16 PM
you can try some purple cool? i think thats what its called -to help it run cooler-
or what ever the auto store has that loweres the temp
Old 01-17-2007, 01:58 PM
YEP OH YEP, it must be the coolant or the new displacement that makes it shoot out the overflow just as soon as it starts up!! Boy you bet you can develope 13 lbs of pressure just as soon as it fires!! Sorry to be so sarcastic, but if anyone read the original post and then wrote that,,well then I guess I am not sorry afterall.
Get the oringed head or get yours oringed.
Old 01-17-2007, 05:14 PM
jason33's Avatar
(wow) what a (real know it all)l
the coolent will keep it cooler after the rebuild espescially if you go with a big bore -or super mini- or just stock ---im not sorry either
Old 01-17-2007, 05:18 PM
Jason, re-read the original post. It is not from overheating. Tdub
Old 01-17-2007, 05:21 PM
jason33's Avatar
blown-(bad) head gasket- i was just suggesting what would help not the cause-
Old 01-17-2007, 05:24 PM
Oooohhh...you mean....like when....I gotcha....I think...j/k
Old 01-17-2007, 06:04 PM
jason33's Avatar
- -- these are fun
really - i don't know what some yahoo has done i wasn't there
but if the head is warped get it resurfaced, or (oringed)- nothing wrong with resurfacing- its been done for years-? since the beginning
torq to (propper) specs
there should be no air in the system -thats why theres a cap with a pressure release,and a over flow tube-incase it does
just putting in water doesnt cut it - it will build up pressure,and change to steam-and will get Hot,and blow the head gasket
bleed the system of air (before problems)-this helps
-some gaskets have a certain way the go on- (up,or down)
some can be put on and will block water holes- be sure to assemble properly
buy a manual- it is a good thing to do--
is this better people-
Old 01-18-2007, 10:08 AM
Old 01-18-2007, 12:37 PM
TUK101's Avatar
Last Online: 09-23-2009 10:03 AM
Does it only spew out coolant until it gets down to a certain point in the radiator? Almost every 2 stroke liquid cooled bike will spit off about a half cup to a cup of coolant and then maintains its level. If it only does it when the radiator is clear full, there is probably nothing to worry about, but if it does it until the radiators are empty then you have troubles. You could have a blown head gasket allowing exhaust to enter the water jacket, thus blowing exhaust through the cooling system. If that where the case though you would have a lot of steam visible. If you are sure that you dont have a blown head gasket then I would try out some cooling additive. I believe that Maxima makes one, or you could check out your local parts store that usually has a pint of it. It does work, I used to have a CR500 that would spit a lot during the heat of the summer and that stuff did the trick.
Old 01-18-2007, 01:57 PM
Ekholm's Avatar
Last Online: Yesterday 11:44 AM
Moto Re: 2000 CR80 COOLANT LEAKING FROM OVERFLOW
I say check the head gasket and maybe try "Water Wetter" or "Engine Ice"
I switched to the Engine Ice when i had my 250 motor modified and it works great plus, it's biodegradable !!!!!
Old 01-18-2007, 06:03 PM
It has been leaking coolant out the overflow on revving, from the moment its started
Old 01-19-2007, 11:04 AM
Yes Tryce, but maybe you and I are missing the point. If the owner uses a biodegradeable purple coolant when the coolant shoots out on the ground the rider and worms will be less likely to be burned, and the stuff will break down quickly. Sometimes we of the "aged" set just seem to miss what is really intended. It took me this long to figure out what the other posters really mean, and I hope this helped you too ;-)
Old 01-19-2007, 02:42 PM
The Baron's Avatar
Problematic Poster
I agree, this bike is not overheating. The head gasket is leaking. Buy an o-ringed head. I never could understand why any manufacturer would build a motor that didn't have an o-ring for a head gasket. It just makes way more sense. I hate doing top ends on CR's, those damn things are tough to get sealed!
Old 01-19-2007, 11:59 PM
TUK101's Avatar
I agree with that. I rebuilt the neighbor kids 80 2 years ago and had a hell of a time getting the head gasket sealed. It basically took about 5 start up, heat up and cool downs before the darned thing sealed. This is after tearing it back down to make sure that it wasnt leaking down the cylinder. Those copper head gaskets just take a lot of heat to get sealed right.
Similar Threads for: 2000 CR80 COOLANT LEAKING FROM OVERFLOW
water in tranny oil and coolant shoots out overflow I like lilbikes 2-Stroke Motorcycles - Kawasaki 2 07-24-2008 11:18 PM
leaking coolant 04blue450 ATV/UTV - Yamaha 8 03-07-2005 09:55 AM
coolant coming out overflow 03cr125 2-Stroke Motorcycles - Honda 7 02-22-2005 09:17 PM
Frame Rail Coolant Overflow For CRF 450 raabit 4-Stroke Motorcycles - Honda 1 11-30-2004 04:07 PM
Coolant overflow bottle MATTXR250R General Discussion 8 12-31-2003 12:14 PM
