Old 06-27-2013, 09:30 AM
Last Online: 07-06-2013 11:24 AM
Default 2000 CR 250 Clutch center
SO I recently am putting in some new plates and had everything back together in my clutch. Still doesn't work. I start re tightening the bolts that hold the springs in and one of them snapped pretty much at the head of the bolt .
any idea how to get it out or should I take the clutch center out and just drill it?
also does anyone know why my clutch when in gear and pulled in does not let the tire roll freely, even after the plates were changed.
All I can think of is an adjustment issue.
thanks guys
Paul
Old 06-27-2013, 09:41 AM
speedysvetz's Avatar
Last Online: 06-12-2019 09:43 PM
thanks guys
Paul
Check for grooves on the basket such as in this one http://img.photobucket.com/albums/v6...1/IMG_2560.jpg
Those grooves will cause the plates to stick and not release it happened on my 97 cr250 im guessing that's your problem
Old 06-27-2013, 01:24 PM
gusco's Avatar
Last Online: Yesterday 09:51 PM
If it is one of the bolts I'm thinking, I would back out the other bolts and remove the hub. Then I'd have access to the shaft of the bolt and be able to grab it with vise grips and back it out.
Old 06-27-2013, 01:31 PM
Last Online: Today 06:19 AM
Default FYI
FYI....With the clutch pulled in and in gear ...The wheel will still have drag on it as you are still turning gear shafts in the gear box...
Old 06-27-2013, 02:07 PM
there is no where to grab the bolt its sunken in the thread too far. I started to drill it out and relized I need to get the clutch center off (which is now a problem). Im going to some plates back in put it in 5th adn try adn get that center nut off.
---------- Post added at 03:04 PM ---------- Previous post was at 03:02 PM ----------
shouldnt the back wheel roll freely when engaged adn the clutch lever pulled in ? like as if it was in neutral?
Im really not sure but mayber when I had it back together it was fine then.
and then I took it apart and f'ed it up.
thanks for all the info guys
---------- Post added at 03:07 PM ---------- Previous post was at 03:04 PM ----------
any information about easiest way to get the center clutch nut off with out actually buying the tool would be greatly appreciated.
Sorry one more thing it goes clutch plate then spacer then clutch then spacer etc?
also when its back together and the cover is still off and you pull in the lever, how much is the pressure plate supposed to come out?
thanks again guys
Old 06-27-2013, 02:26 PM
Default ??????
You really need to pickup a service manual for your bike.....
As stated before.....The wheel will not spin freely when in gear and clutch lever pulled as you are turning gear shafts in the trans. That is why they don't start very well in gear as well.
Also, if the bolt broke off at the head as stated, there will be enough sticking out of the center hub to get vise grips on.
Old 06-27-2013, 03:06 PM
thanks again guys
My 2009 yz drags the tire a little bit when I roll it and put it in gear until the clutch lets off then it moves freely
Old 06-27-2013, 03:47 PM
I have the service manual, I found its good for specs but doesnt tell enough "how to" I found you tube was better.
---------- Post added at 04:47 PM ---------- Previous post was at 04:41 PM ----------
ok Im gonna get the bolt out and get a new one and put it back together and see where Im at.
Old 06-28-2013, 05:29 AM
Last Online: 07-09-2013 10:29 AM
I would replace all those bolts more than likley they r stretched a bit from over tightening ...replace em before another breaks
Old 06-28-2013, 08:53 AM
good idea
thanks dude
Similar Threads for: 2000 CR 250 Clutch center
2000 Yz 125 Need Clutch HELP codybb 2-Stroke Dirt Bikes - Yamaha 0 05-20-2011 06:56 PM
2000 CR250 Fork Center Bolt... Ride4Lif3 Dirt Bike Suspension Tuning 2 03-25-2011 08:58 PM
LOOKING FOR: Center Clutch hub for 1989 CR250 Tonyklem Classified Ads 4 06-19-2006 09:59 PM
2000 CR 250 clutch drags oroepke 2-Stroke Dirt Bikes - Honda 5 08-23-2004 10:24 AM
2000 YZ125 Clutch Re-assembly,HELP motojonny 2-Stroke Dirt Bikes - Yamaha 7 05-16-2004 12:25 AM
