Old 10-01-2013, 02:46 AM
crchris's Avatar
Last Online: 12-11-2013 09:42 AM
Default 2000 cr 125 blow by
My 2000 cr 125 has a lot of oil coming from the expansion chamber where it meets the cylinder, I think its jetting but bike seems to run just fine when its warmed up. Any suggestions?
---------- Post added at 12:46 AM ---------- Previous post was at 12:36 AM ----------
if it helps at all, I just did a top end rebuild. Before thr rebuild it did this but not nearly as bad.
Old 10-01-2013, 06:41 AM
Last Online: Yesterday 08:26 PM
Default ???????
What does your spark plug look like?
What fuel mix are you using?
Have the crank seals been changed?
Have you checked your float height?
Old 10-01-2013, 09:50 AM
bjunior's Avatar
novice
Last Online: Yesterday 12:31 PM
WHAT ABOUT REPACKING silencer. also check the premix it should be about 32/1.
Old 10-01-2013, 10:09 AM
arnego2's Avatar
Last Online: 01-09-2018 02:14 PM
If you are sure its blow by pull the piston and get a new one. Those pistons shatter, specially when running too loose in their cylinder.
Old 10-01-2013, 10:42 AM
VAL's Avatar
VAL VAL is offline
Last Online: 06-09-2020 07:00 PM
Double check the mating area where the pipe meet the port. O-ring may have torn or rolled.
Old 10-01-2013, 11:09 AM
crchris's Avatar
My spark plug is pretty black, im going to change it tonight and I run 32:1 maxima pre mix. And no ive never changed the crank seals.
---------- Post added at 09:09 AM ---------- Previous post was at 09:06 AM ----------
The o ring is torn in half.. thats probably why it comes out of the expansion chamber but why would so much come out?
Old 10-01-2013, 11:59 AM
Default OK
Ok if plug is black then you are running rich.
If the crank seals have not been changed on a 14 year old bike, then do so ASAP.
Also set the float level and make sure the needle is shutting off fuel flow.
If you are attempting to run a fuel mix using less oil, like a 40 : 1 or a 50:1 then that will make you run rich.
Pick up a service manual for your bike.
Old 10-01-2013, 10:12 PM
crchris's Avatar
I have a service manual but it doesnt tell me much about problems like this, the bike was preowned so I couldn't tell when the last rebuild on anything was but ill tare it down soon and change the seals. Thanks guys.
Old 10-02-2013, 10:58 AM
Papagonz's Avatar
Last Online: 05-11-2016 04:04 PM
+1. It's actually very easy to do and can save your motor.
Old 08-30-2018, 10:32 PM
Last Online: 08-30-2018 10:32 PM
2000 cr125 with alot if money in and less than 10 hours on a top end less than 5 on a new transmission. running 40:1 with motors cross power full synthetic but I still have alot of after birth from my silencer especially when it's cold it's Smokey af it gets better as it warms up but jetting ? maybe ? runs great and has lots of jam .it bogs a bit
---------- Post added at 10:32 PM ---------- Previous post was at 08:41 PM ----------
Similar Threads for: 2000 cr 125 blow by
How to blow the holeshot NYMXer Photo & Video 19 10-24-2006 11:44 AM
Big bore blow up?? dixienw123 4-Stroke Dirt Bike Bike Forums 3 10-10-2004 01:58 PM
426 question on blow by Thumper426 4-Stroke Dirt Bikes - Yamaha 9 09-05-2004 10:33 AM
Did I blow my crank? bottomed_out 2-Stroke Dirt Bikes - Honda 22 04-26-2004 07:55 PM
Is it oil blow By? Dirtbikindad393 4-Stroke Dirt Bikes - Yamaha 8 09-19-2003 11:42 PM
