Old 03-24-2014, 05:39 PM
Detroiit's Avatar
Last Online: 05-20-2014 04:17 PM
Default 2 crankcase gaskets with my 0em kit?
I received 2 gaskets in my OEM honda kit. 11191 kz3 880 and 11191 kz3 j20 . From what i gather the j20 is for 2000 cr250. Is there a purpose i have it in my kit? or they just cover both bikes?.. I'm having my counter-shaft bind up when i put the case bolts in that side? The bearings are seated properly and the washers and gears are absolutely in specified order according to the honda manual. Am I suppose to use both gaskets? I noticed my counter shaft seems to sit about .71 mm higher that the main shaft. (Gear sits slightly higher) ??? I'm at a loss. The assembly seems to shift and rotate and when I spin the shafts in the right side of the case they spin effortlessly. If every thing is seated and assembled right what else could cause this problem? Gasket thickness?
Old 03-24-2014, 05:44 PM
Last Online: Today 10:00 AM
Did you read dogger's reply in your other thread?
Old 03-24-2014, 06:57 PM
JMV's Avatar
JMV JMV is offline
Maybe if you start enough threads about the same problem, it will fix itself....
Similar Threads for: 2 crankcase gaskets with my 0em kit?
NE Gaskets. stevo450 Product Reviews 4 08-02-2013 02:22 PM
Will a cr125 1997 left crankcase fit to a cr125 2000 right crankcase? beont 2-Stroke Dirt Bikes - Honda 3 05-20-2011 10:19 AM
gaskets daver1 ATV/UTV - Suzuki 0 05-13-2010 01:40 PM
Athena gaskets Ricksta General Discussion 0 06-12-2008 10:41 PM
I have oil leaking and i need gaskets Lane ATV/UTV - Polaris 3 07-03-2007 09:37 PM
