1998 cr125 keeps floodingThis is a discussion on 1998 cr125 keeps flooding within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; Well i got my bike going today and i was riding it and taking it easy cuz it has a ... |
| Well i got my bike going today and i was riding it and taking it easy cuz it has a new top and bottom end. I noticed that it was kind of bogging down and didnt have full power. well i figured that my jetting was probably wrong since its kinda cold outside so i went and got a new jet and put it in. it started up first kick and rode it a little and it still wasnt quite right so i parked it and decided i would try the air screw. then when i went to start it again it wouldnt start. i kicked it a few times then decided to check the plug and it was flooded. so i changed back to the other jet that was in it originally and it still was flooding. so after that i took off the carb, removed the reeds, and took off the head and cleaned them all and after all that it still didnt start. it has good compression and good spark so i know its not that. Right now i have a 178 and 50 jet in and i dont know if that could be the reason it wont start. let me know what you think it might be. thanks. |
| That's a pretty big main you have in there...I have a 170 in mine. Cold weather should lean out your mixture a little bit, but you still might try taking the needle up a notch. Check your float and also the obvious stuff - make sure you're not leaving the choke on all the time. Your carb has the idle speed adjust and the choke on the same stem, right? |
| i checked the float and its working fine and i havent been leaving the choke on. and yes it has the idle adjust on the choke. im thinking sinces its been like 50 degrees outside that i should just get a smaller main. how small should i go? |
-Kevin- |
| thanks i will try that first |
| No offense to you memory KKX...but it's 16mm |
| 15mm +/-1mm Is that better? |
| 1998 cr125 drain bolt size | jhouser | 2-Stroke Motorcycles - Honda | 1 | 11-04-2008 06:25 AM |
| Cr125 1998 Seized bottom end... crank will not turn! | Rocky_mx | 2-Stroke Motorcycles - Honda | 8 | 01-06-2008 08:44 AM |
| Flooding problem | spartanbiker_117 | 2-Stroke Motorcycles - Honda | 27 | 05-30-2007 03:10 PM |
| FOR SALE: 1998 Honda CR125 $2,200..... | ShaneRider | Motorcycles & ATV's | 1 | 06-25-2005 07:58 PM |
| Let the flooding begin..... | huffdaddy70 | 4-Stroke Motorcycles - Yamaha | 2 | 03-04-2004 11:12 AM |
