Old 10-17-2016, 10:39 PM
Last Online: 11-19-2016 01:34 PM
Default 1997 CR250 Rebuild - Clutch Won't Disengage
Hey guys. I've already went through the search here and google but can't seem to find a good solution. I went through a complete top and bottom end rebuild on a '97 and I'm finding my clutch won't disengage in any gear.
The bike did run fine before the rebuild. Clutch disengaged as normal. Clutches used are the ones before the rebuild.
Here are the symptoms
- the clutch cable has no effect even at it's tightest or loosest
- the clutch bell does move out when the clutch is pulled in
- bike instantly dies in any gear other than neutral
- I cannot move the inner clutch basket after I tighten down the nut. This is without any clutches in the basket (normal not normal?)
- I can move the inner clutch basket when the nut is not tightened
- Nut is tightened to spec (59 ft lbs)
- plates/clutches are facing the correct way
Things I've changed:
- Seals, bearings, crank, cylinder, etc
- 80w Honda oil
- Steel clutch plates instead of aluminum (maybe this is an issue?)
- reused old clutches
I've double checked to make sure I wasn't missing any parts in the clutch assembly. My understanding is that the clutch basket should move freely in all gears but this doesn't seem to be the case when the nut is tightened down. As per the manual I have the clutch collar in, then the roller bearing, outer clutch, thrust washer, basket, thrust washer, lock washer, nut, clutch lifter assembly, plates & clutches, bell and springs. So assuming I'm not missing pieces, what could be going wrong?
Old 10-18-2016, 07:23 AM
Last Online: Today 07:30 AM
There may have been a washer not put back in place between the clutch parts. There is one between the basket and the inner hub and one behind the basket.
Old 10-18-2016, 07:32 AM
Last Online: 06-30-2020 11:30 AM
My thoughts as well.
Old 10-18-2016, 10:33 AM
I got the one behind the basket (large thick washer) but are you talking about 5 in this picture? I've got that also.
cdn.partzilla.com/diagram/honda/hom/b3c2bc14cda4a6a66a9f26a83c1e550a6bb52cd8.png (Link to picture because my post count is so low)
Thanks for the help so far
Old 10-18-2016, 12:25 PM
no this is no normal should turn freely, also steel plates have nothing to do with this.
they are probably talking about the No17 thrust washer, if that is missing then the inner binds to the outer probably but i think you said that you've use that properly so it might be something else, maybe you installed the two thrust washers the other way around?
check for clearance issues by tightening the nut by hand slowly and turning the inner basket to see if it binds with the outer clutch basket.
Old 10-18-2016, 12:48 PM
So I went back and messed with it. There definitely is clearance issues. I for sure have washers 17,18 and 19 in the correct place. Somehow the inner bell is binding with the outer bell. This is weird because the bells showed no issue prior to the rebuild. Maybe something is missing in on the main shaft transmission side? It's not loose and the gears shift fine...
Old 10-18-2016, 02:25 PM
JMV's Avatar
JMV JMV is offline
I had an issue with a CR500 where the gear that is pressed into the center of the clutch basket had moved around ~1/32" or so. When I tightened the center nut it locked up as you are describing. I just threw it in my press, pushed it back in the problem solved. Worth a look.
Old 10-18-2016, 03:10 PM
2 other possibilities.....
1. Was the nut over tightened? If so it may have crushed the bearing just enough to allow for lock up.
2. If the basket is not totally seating in both the idler gears it will lock up when the nut is tightened.
Similar Threads for: 1997 CR250 Rebuild - Clutch Won't Disengage
1997 honda cr250 rebuild Bigdaddiebrad 2-Stroke Dirt Bikes - Honda 8 04-23-2014 05:55 PM
Clutch wont disengage maxhax2000 2-Stroke Dirt Bikes - Honda 14 03-01-2013 03:14 PM
KX 65 clutch wont disengage Luckyduck272 2-Stroke Dirt Bikes - Kawasaki 5 12-29-2010 04:43 AM
95' cr 250 / clutch won't disengage brotherxl600 2-Stroke Dirt Bikes - Honda 11 11-11-2010 08:20 PM
1997 CR250 Clutch Replacement NBL_BMX377 2-Stroke Dirt Bikes - Honda 3 03-14-2007 08:19 PM
