Old 12-07-2017, 11:24 AM
2trebel's Avatar
Last Online: 04-04-2018 07:30 PM
Thumbs down 1997 CR125R Exhaust Issue
Hey everyone, so I have a 1997 CR125R that has just recently before buying it had a full top to bottom rebuild, it runs great and looks pretty good aswell.
But my problem is that the bike shoots a black oil out of the back silencer, not a lot but enough to dirty up my fender and side panel and a little bit of the swingarm and rear caliper. It also only seems to spit the oil when I'm in high rpms, it doesn't smoke alot and my oil comes out the same amount I put in so I dont believe its crank seals. My jetting is very close to stock (see below).
172 Main
55 Pilot
3rd Clip Position
The bike doesn't ever bog and when I open up the throttle it rips super nicely, just the oil is super annoying and the only thing I could think of is my jetting.
Thanks guys.
Old 12-07-2017, 11:54 AM
Last Online: Yesterday 09:46 AM
You could try changing your fuel/oil mix ratio, but if the bike runs good otherwise and the plug color looks okay I'd be hesitant to mess with it.
Old 12-07-2017, 12:01 PM
2trebel's Avatar
Yeah it doesn't foul plugs, the plug color is a dark ish brown and I mix 32:1 with lucas oil and 91. But I'm thinking of maybe switching to a 170 main I think that could fix it what do you think?
Old 12-07-2017, 12:03 PM
I am the furthest thing away from a jetting expert you could ever find... hopefully one of our members more knowledgeable in that area will chime in.
Old 12-07-2017, 01:15 PM
Last Online: 01-17-2019 07:38 AM
It won't hurt to drop to a 170 since it is such a small change, but I doubt it will help much. Like Cowboyona said you might want to change your fuel/oil mix ratio or try another brand of oil.
Old 12-08-2017, 11:39 AM
gusco's Avatar
Last Online: Yesterday 11:19 AM
A little bit of spooge is normal. If the silencer has not been repacked, I would assume it soaked up some spooge and the high rpm is forcing it out of the fiberglass wool. If it's running well, I would take care of that (and cleaning out the whole exhaust system while it's apart for service) first.
Similar Threads for: 1997 CR125R Exhaust Issue
Revving Issue on 1997 RM125 Tro151 2-Stroke Dirt Bikes - Suzuki 29 05-23-2018 01:31 PM
1992-1997 Honda CR125R Motorcycle Service Maintenance Repair Manual mattcuda71 2-Stroke Dirt Bikes - Honda 71 11-28-2017 09:07 AM
1997 YZ125 Kickstart issue Ecstatic 2-Stroke Dirt Bikes - Yamaha 2 09-14-2017 05:27 AM
Does anybody know diameter of exhaust/muffler port on a 1997 rm 125 rm4070 2-Stroke Dirt Bikes - Suzuki 0 08-27-2013 03:30 PM
2001 cr125r exhaust flange hondaman63 2-Stroke Dirt Bikes - Honda 1 10-28-2003 07:22 PM
