1997 CR125 Water pump help.This is a discussion on 1997 CR125 Water pump help. within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; my honda cr125 has a water leak and every were ive looked it points to the water pump seal can ... |
| my honda cr125 has a water leak and every were ive looked it points to the water pump seal can someone tell me how to take it off as im new to this thanks kei |
| If you want to work on your bike, the first thing you need is a good service manual. I recommend a Clymers or better yet, the Honda shop manual. You will need a new water pump seal, a set of water pump gaskets, a gear jammer device suitable for platic gears and a torque wrench along with the usual metric tools. I covered water pump seal installation in a series of post dealing with a CR250 engine. Your 125 water pump is nearly identical so that information and pictures should be helpful. Search back for posts entitled "Honda CR250 Engine build". Once you have the parts, tools and information, the actual job is fairly straight forward and easy. Keep us posted. dogger |
| Water Pump Corrosion | SilverCJ-7 | General Discussion | 5 | 06-02-2008 03:40 PM |
| 250F leaking water from bottom of water pump | lsqrus | 4-Stroke Motorcycles - Yamaha | 2 | 09-09-2007 12:05 AM |
| Water pump gasket | Bluerider250 | 2-Stroke Motorcycles - General Discussion | 2 | 04-30-2006 09:53 PM |
| rmz 450 water pump | casey392 | 4-Stroke Motorcycles - Suzuki | 1 | 08-30-2005 05:23 PM |
| KXF/RMZ 250 Water Pump/Oil Cover Fix | factory | General Discussion | 5 | 10-31-2003 04:59 AM |
