1997/1999 CR250 engine swap
This is a discussion on 1997/1999 CR250 engine swap within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; My sons '99 CR250 engine siezed. When I took it apart I found that the piston skirt broke and busted ...
Old 05-20-2009, 06:48 PM
Kev_CR's Avatar
Mud sampler
Last Online: 10-11-2009 01:57 PM
Default 1997/1999 CR250 engine swap
My sons '99 CR250 engine siezed. When I took it apart I found that the piston skirt broke and busted up both L/R engine cases internally.
I found someone who is selling a '97 engine complete with carb and electrical for a decent price. My question is will this bolt right into the '99 frame? If so, any suggestions on if I should just use the bottom end off of the '97 and the electrical, cylinder and carb off the '99? From what I've read the '97's porting is more aggressive, so should I use the '97's cylinder if I wanted more top end? Or what combination of parts would be recommended?
Old 05-21-2009, 10:07 AM
dogger315's Avatar
Last Online: Today 07:34 PM
The '97 motor will bolt right in to your '99 frame. The '97 motor does have
a bigger hit and a little more overrev than the '99 which had a rider friendly
usable powerband, but was a little weak on top.
I recommend using a Stealhy flywheel to smooth out the "hit" a bit. That
way you get the best of both worlds without any permanent changes like
porting. The flywheel will help the bike hook up better and delay the onset
of rider fatigue/arm pump to later in the moto.
The '97 used a Keihin PWK carburetor with TPS. Honda got the "boost"
timing wrong with that setup which only added to the explosiveness of
the powerband. I'm not sure if that problem still exsisted in '99 or if the
port timing change was the fix. Since you have a perfectly good ignition
on your '99, I would swap that over to the '97 along with the '99 coil
('97 coils were prone to failure).
Sounds like an interesting swap, good luck with it.
dogger
Old 05-21-2009, 03:41 PM
ctroger24's Avatar
Last Online: 11-17-2009 05:16 PM
I actually did this swap myself. I bought a 99 roller that the engine was almost beyond rebuilding, but found a good deal on a 97 engine. I swapped everything from my 99 over to the 97 engine ie: carb, stator, ecu, fly wheel, and coil. Everything fit and worked perfectly. I didnt even have to mess with the jetting. The cases between the two are itentical so fitment is not an issue. Once your done you can sell the rest of the 97 stuff on Ebay to help pay for the swap. Good luck!!
Old 05-21-2009, 05:06 PM
Kev_CR's Avatar
Mud sampler
Thank you both for the info!
I've got a Stealthy flywheel weight on the '99 engine that I'm definitly going to move over. That was one of the better mods I've done.
Old 05-22-2009, 12:43 AM
Kev_CR's Avatar
Mud sampler
Well, I went and picked up the '97 engine for $400 with carb and electrics. I'm going to rebuild the top end on it and get it installed sometime this week hopefully. I'll post the results.
Old 05-22-2009, 12:50 AM
I've been RM-Zedded
Last Online: Today 03:53 AM
Right on! Good luck with it.
Old 05-23-2009, 05:53 PM
Kev_CR's Avatar
Mud sampler
I put the engine in today using the parts from the '99 that ctroger24 did with his swap. Everything went smooth, except I had to travel a distance to get a flywheel puller .
Anyhow, the bike fired right up and rides good, jetting feels to be close if not spot on. I'll have to do some throttle chops to confirm.
Old 05-24-2009, 01:27 AM
I've been RM-Zedded
Right on... that sounds like it wasn't too bad at all. Well, with the exception of the flywheel puller
Old 05-24-2009, 10:41 AM
AJ_YFZ's Avatar
MX JUNKIE
Last Online: Today 05:04 PM
Sound like you spent less rebuilding with the donor motor than you would have with a rebuild....Congrats Man...
Old 05-24-2009, 11:04 AM
Kev_CR's Avatar
Mud sampler
Thanks all, yeah it ended out working out good. I spent about 3 hrs doing the work and I was taking my sweet time. I didn't do a new piston/rings yet though. I inspected the piston as much as I could through the intake and exhaust ports and it looks to be good. The compression tested at 175 ish, which is pretty close to what my old engine did with my compression tester with a new broken-in piston/rings.
I'll do a top end within the next couple weeks though just to start fresh. First I need to clean up some of the old parts and get em' on ebay.
Tags
cr250, cr250 engine swap
Similar Threads for: 1997/1999 CR250 engine swap
1999 CR250 ENGINE PARTS ctroger24 MC & ATV Parts & Accessories 10 07-30-2009 02:46 AM
1992 CR250 engine swap DavidCR250 2-Stroke Motorcycles - Honda 3 01-21-2009 03:45 PM
1999 cr250 engine help ctroger24 2-Stroke Motorcycles - Honda 3 11-30-2008 12:01 AM
1999 CR250 PARTS NEEDED: ENGINE, PIPE, REEDS AND MORE PLEASE HELP! ctroger24 Wanted Items 0 11-28-2008 01:03 AM
cr250 frame/ cr125 engine swap Kanookie 2-Stroke Motorcycles - Honda 3 01-02-2008 09:38 PM
