Old 06-17-2014, 10:45 PM
Last Online: 09-08-2014 11:25 PM
Default 1995 CR250R rebuild/HP/Torque
I have a beautiful 250 I got from my brother in law he was the 2nd owner. Both of them only put a total of 60 hours on the bike. I've had it for 2 years and I'm ready to give it an internal makeover. Please help me with suggestions. Full FMF gold series pipes, Renthol alum sprocket. I'm about ready to put on A V Force 3 reed, redo head gasket, piston rings and air filter.
Old 06-17-2014, 11:10 PM
Papagonz's Avatar
Last Online: 05-11-2016 05:04 PM
When you have the jug off I would suggest checking the rod for up and down play. The manual will tell you how much play is allowed, if its out of spec I would look into doing the bottom end as well. You should have a manual before opening it up, if you don't, I can send one over.
Old 06-17-2014, 11:23 PM
So another question, what is the stock piston size?
---------- Post added at 09:23 PM ---------- Previous post was at 09:22 PM ----------
If you could send me a manual I would be very grateful.
Old 06-18-2014, 03:45 PM
dogger315's Avatar
Last Online: 08-31-2019 06:04 PM
The '95 had a pretty stout motor right out of the box, in fact the '95 cylinder
is the best of the 92-96ers.
Before I offer any advise I need to know what kind of riding you do...Trails,
MX, play riding, etc. An FMF fatty, silencer, VForce 3 and Keihin PWK will
make a good motor better for MX, but not so much for technical trails.
66.4 mm
dogger
Old 06-18-2014, 11:27 PM
I ride trails, track, and sand. Soo 66.4 is the stock size, I did some searching last night and it said 66.34. I'm a little rusty on my mechanical side. What is a Keihin PWK? I have the fatty on there. I'm just looking for some ups that will help me keep up.
Old 06-19-2014, 09:12 AM
dogger315's Avatar
The PWK was the next generation of carbs from Keihin. Your CR came
with a PJ. While it was a decent carb, it lacked some of the tuneability
of the PWK which came standard on most of the other brands. Switching
to a PWK will net you better throttle response and it's easy to jet and keep
jetted.
If you want a little boost, the easiest is to mill the head and rework the
squish to net a better burn and up the compression. Any competent
tuner can do this for you, but don't go overboard or you'll be stuck
running race gas. Combine the head work with a VForce 3, the Fatty
with an FMF long silencer and PWK and you should get a nice boost
in power with a fairly broad powerband.
dogger
Old 06-19-2014, 08:47 PM
Well this sounds very good. So piston size 66.34 or 66.40? Or is there that big of a difference? I've been looking at the PRO X any other suggestions? How much are those carbs running for?
Old 06-20-2014, 05:54 AM
Hondaboi's Avatar
Last Online: 08-12-2015 06:40 AM
I would always go with a OEM piston from Honda, they are pretty cheap, if your doing the top end make sure you do gasket, piston, rings, wrist pin and bearing and new C clips.
I rebuilt the top of my 250 every year, it takes about 2 hours total from stripping the plastics to putting them back on. good luck!
Similar Threads for: 1995 CR250R rebuild/HP/Torque
1995 cr250r piston karracing 2-Stroke Dirt Bikes - Honda 5 07-03-2012 09:07 PM
1995 CR250 Rebuild wagonproject 2-Stroke Dirt Bikes - Honda 16 09-28-2011 06:15 AM
1995 honda cr250r help hom3gr0wn 2-Stroke Dirt Bikes - Honda 3 06-07-2010 11:07 PM
1995 XR280R Complete Rebuild... b dawg 311 Classified Ads 1 09-21-2003 03:30 PM
1995 XR280R Complete Rebuild... b dawg 311 Classified Ads 0 08-24-2003 09:12 PM
