1992 Cr250 shock overhaul ?
This is a discussion on 1992 Cr250 shock overhaul ? within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; looking to overhaul the rear shock on my 92 cr250. Anybody got a detailed write up or exploded diagrams of ...
Old 10-19-2009, 04:07 PM
Last Online: 12-20-2009 01:57 AM
Default 1992 Cr250 shock overhaul ?
looking to overhaul the rear shock on my 92 cr250. Anybody got a detailed write up or exploded diagrams of the shock ?
also what make were fitted to the 92 ?
any other tips much appreciated
Old 10-24-2009, 11:43 AM
dogger315's Avatar
Last Online: Yesterday 08:40 AM
For a complicated job like this I highly recommend you pick up
either a Honda or Clymers service manual. You will also need
some specialized tools and a way to recharge the Nitrogen.
The '92 came with Showa suspension.
dogger
Old 10-24-2009, 03:14 PM
thanks for the reply dogger, i have the Haynes manual but it shows nothing. Ive now found a good step by step guide and have completed the rebuild, luckily we use nitrogen in work to recharge hydraulic accumulators so im all sorted.
Looking forward to your 93 build, im just ahead slightly after rebuilding my shock. Just waiting for my swinging arm rebuild kit, didnt realise theres so many items involved.
Old 10-25-2009, 09:35 AM
dogger315's Avatar
Too bad you already ordered one. I have a Pivot Works kit I
bought when I was going to rebuild a used swingarm. Since
then I decided to go with a new arm and it already has the
bearings, collars and seals installed. Guess I'll keep the kit
for when this one needs rebuilding.
Glad you got your shock rebuilt without problem - it's very
cool to have your own stash of N2 at work.
dogger
Old 11-05-2009, 12:42 PM
now i think i may have a problem lol i was nearing the end of the rebuild of the shock, all filled with oil and air removed, the instructions said after circlips fitted to retain the seal head , pressurise the reservoir to 90 psi and try to move through its full stroke. Now here is the problem, as i was pressurising oil hit the roof lol there was a needle valve or something with in the main shaft which came out, i forgot to refit the clevis on the end of the shaft which would have prevented it coming out.
so i stripped down and started again but now when full of oil and with some gas in the reservoir, it seems too easy to press down on the shaft as compared to before i had the needle valve blow out. seems this valve is passing oil or air through , dont suppose anybody has any ideas ?
cheers
daz
Similar Threads for: 1992 Cr250 shock overhaul ?
PARTING 1992 CR250 COMPLETE ctroger24 MC & ATV Parts & Accessories 0 04-13-2009 12:00 PM
1992 CR250 engine swap DavidCR250 2-Stroke Motorcycles - Honda 3 01-21-2009 02:45 PM
technical info required 1992 cr250 smiffy123uk 2-Stroke Motorcycles - Honda 2 10-23-2008 04:56 AM
1992 CR250 Question Fireman87 2-Stroke Motorcycles - Honda 2 10-29-2007 06:24 PM
how much fork oil in 1992 cr250 souphmars 2-Stroke Motorcycles - Honda 5 09-15-2006 07:31 PM
