Old 03-25-2015, 10:46 AM
Last Online: Today 07:07 AM
Stevo...another good option.
Old 05-28-2015, 08:54 AM
Update...I bought a 1820KY 36 hole rim from pro wheel and it fit like a glove! Although it is not listed for the 88 CR250, it fits. Spokes are still available from Honda.
Old 03-17-2017, 06:28 PM
Last Online: 10-02-2017 06:03 PM
Default 1988 Cr125
Hi guys,
Same Problem,
The Cr125,250 & 500 have the same hub in 88. Specs(E1 BLACK - 20MM AXLE - BRG TO BRG 138.5MM - ROTOR OD 220MM ID 122MM - BOLT CIRCLE 6 ON 143MM - SPROCKET BOLT CIRCLE 6 ON 153MM - 36 SPOKES - FITS 87-88 CR125 CR250 CR500 42601-KS6-700ZA 1988 )
Currently have a usable hub 36 hole but would need spokes and rim. (gold- 18 or 19 inch rim- spokes depending on size)
After reading some of the solutions posted above.
Do you know if there would be any issues swapping the whole hub and wheel for a newer year 32 hole set up? might save me some trouble
It seems as though the 88 cr125 had a different swing arm then any other year. Not sure how much that makes a difference with the rear hub fitting up.
Any help
thank
Old 03-20-2017, 07:10 AM
I would stick with the factory style 18 inch rim. You can still buy spokes from Honda, but at $3.61 from Partzilla that adds up to $130 plus shipping. You may be better off to find a used wheel on ebay or a m/c scrap yard. You can try this guy. MrSuperSport@yahoo.com or 208-771-0882
Old 03-20-2017, 10:16 AM
Last Online: Today 09:38 AM
You may be able to swap the whole wheel assembly, but you may run into issues with wheel spacers and axle sizes. Check out the following links:
Honda CR125 Bike ID
Honda CR 250 ENGINE
Honda CR 450
That's the most complete source of cross-reference info I'm aware of. You can also go to partsfish.com and find the OEM part number, then search for it and and cross-reference it that way.
Similar Threads for: 1988 Honda CR250 rim
1988 Honda cr250 cylinder Brett Campbell 2-Stroke Dirt Bikes - Honda 0 07-14-2014 09:16 AM
Honda cr 250 1988 engine rebuild. Easycyprus Dirt Bike Restorations and Builds 1 12-02-2012 11:21 AM
1988 Honda CR125 notaleg13b Classified Ads 0 05-18-2012 07:22 PM
Stock sprockets 1988 Honda CR250R SilverCJ-7 2-Stroke Dirt Bikes - Honda 1 02-11-2012 06:19 PM
1988 Honda XR-250r Parts? BigOX Vintage Riding 1 08-22-2011 07:00 AM
