Old 06-02-2016, 01:34 PM
Last Online: 06-02-2016 03:49 PM
Default 1986 CR250 Idle Surge
Hello all,
I recently picked up a 1986 CR250. Having one hell of a time figuring out my surging idle issue. Here is what i have tried so far :
And here is a video of the idle while messing with the idle screw. : ( will post link after my 5 posts) My youtube name is "Supersickns" if anyone wants to watch it.
  • Set the idle screw 1.5 turns out. The bike will only idle near as it should if the screw is literally 1/8th a turn out. No more no less. At 1:30 in the video is what it idles like with the screw set in the 1.5 turns out position.
  • Pulled the PJ carb off and confirmed it has the correct #175 main jet, #60 pilot jet. The float valve is good. I may need to adjust the float level a bit.
  • Ive taken the reeds off and inspected them and they are all good. Even tossed another set i have in to see if it made a difference and it hasnt.
  • Put a BR9EG plug in the bike (Previous owner has the wrong plug (BR6ES) installed. I know a BR8EG/ES is the factory plug but a BR9 is a better option than the BR6.
  • My next step is going to be 1. Float level, and 2. Trying a PWK carb that i have as well. That carb has a 185 main 55 pilot jet setup. Just to see what if any difference it makes.
Old 06-02-2016, 02:54 PM
Last Online: Yesterday 09:57 PM
The idle mixture screw setting of 1/8 turn indicates to me that you are lean for some reason. Maybe a small air leak or restricted fuel flow.
Now keep in mind that some of the mid-80's cr's of 125 and 250 had a serge in them when all was spot on, so you may not cure it 100%.
What does the spark plug tip color look like?
The reason I ask is that is it possible for you to have an air leak and also have a float level that is set too high and it will give you a problem sorting it out.
Old 06-02-2016, 03:33 PM
I will check those things out and reply back. Once i reach my 5 post limit i can share the video link.[COLOR="Red"]
Old 06-04-2016, 04:03 AM
Wolf's Avatar
Last Online: 11-14-2016 01:00 PM
Do a pressure test, (search the forum for how to)
You might have a leaking gasket somewhere.
Similar Threads for: 1986 CR250 Idle Surge
1986 cr250 clutch coner Gmcduff Dirt Bike Restorations and Builds 2 04-06-2016 12:28 PM
WTB 1986 CR250,500 Fork Roadrider Classified Ads 0 01-30-2016 02:59 PM
1988 CR250 Slight "Lean Surge" MotoManNJ 2-Stroke Dirt Bikes - Honda 8 11-04-2013 05:31 PM
What is engine blubber/surge? maxhax2000 2-Stroke Dirt Bikes - Honda 2 03-12-2013 11:42 AM
cr250 1986 head gasket again&again help carlcr2501986 2-Stroke Dirt Bikes - Honda 11 04-18-2011 03:49 PM
