Old 12-04-2017, 07:33 PM
Last Online: 04-07-2018 02:30 PM
Default 1986 cr250 compression test
So I decided to double check the compression. Goes up to 180 then slowly back down to 0. It suppose to hold the test pressure ?- yes. What do I do next. Is it time for a one over bore job & new piston and rings.
---------- Post added at 08:33 PM ---------- Previous post was at 07:55 PM ----------
Sprayed soapy water around the head, no bubbles (leaks) ??????
Old 12-04-2017, 09:12 PM
Last Online: Today 01:08 PM
Sounds like your are confusing a compression test with a leak test. A 180 reading on a compression test is good. Your piston and rings should have some life left in them.
You can do a leak test and it should hold about 6psi for a minute or so to be good.
Old 12-05-2017, 10:54 AM
Thanks paw paw. Just trying to cover all my bases, for why the dam thing won't start. A little confused, cause I've watched videos of compression test where there gauge holds the pressure longer then mine does.
Old 12-06-2017, 05:42 AM
Last Online: Today 06:08 AM
Sounds like your gauge is faulty.
Old 12-06-2017, 06:59 AM
It's brand new from NAPA
Old 12-07-2017, 06:07 AM
It shouldn't leak down. It is suppose to hold the highest reading. Mine has a Schrader valve, just like the one in your inner tube, and it holds the pressure until I release it.
Old 12-07-2017, 07:03 AM
Pulled cylinder off last night. Of course my luck piston, rings, & cylinder all look fine. Going to get it checked out. Thanks everyone's replies.
Similar Threads for: 1986 cr250 compression test
1986 cr 500 compression test Ronscycle1 2-Stroke Dirt Bikes - Honda 1 03-04-2013 09:10 PM
compression test help ed_563 2-Stroke Dirt Bikes - Honda 17 06-04-2011 01:40 PM
rm 250 compression test bbeach80 2-Stroke Dirt Bikes - Suzuki 2 12-08-2010 08:48 AM
cr250 compression test livetoridecr77 2-Stroke Dirt Bikes - Honda 11 04-25-2008 08:55 PM
yz 125 compression test Moto man26 2-Stroke Dirt Bikes - Yamaha 4 12-21-2006 01:10 PM
