1986 CR 125 ProblemsThis is a discussion on 1986 CR 125 Problems within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; I am a newbie.
well to start it off when the bike is cold it does not like to start. ... |
| I am a newbie. well to start it off when the bike is cold it does not like to start. It usually takes some screwing around with like taking the plug out and cleaning it and putting it back in. It usually take about 15-20 minuets to start it when its cold. but when its warm it starts on the first or second kick. what could be wrong with it? Is it the mixture of the oil? I am currently using 40:1 with Br8es NGK plug. Should I use a hotter plug and a lighter fuel mixuture? anything will help thanks. I am going riding/camping this weekend for memorial day weekend so I am trying to figure this out before then. any suggestion i would greatly appreciate it, thanks again ~James |
| Sounds like you might be a bit rich, So ur plug is usually black to start with? |
| so what do you think I should mix it at? do u think i should get a hotter plug too? what two stroke oil do you prefer to use on CR's? thanks yeah because when you start the bike on a brand new plug it starts on first kick and then if you let it sit it won't start. if you take the plug out it is pure black. what do you think i should do? thanks again ~James |
| use a brand new plug and a br9eg plug. |
| what should I mix the gas at so that it is not too rich for it? I am mixing it at 40:1 right now. |
| First off a hotter plug is not the answer, the correct plug for the bike is a BR9EG. You mix is fine that wouldn't cause this. Question: How old are the reeds in the bike? If you can't answer probably wicked old. I'm betting the hard starting is possibly due to worn out reeds. This bike is before carbon fiber reeds epoxy reeds (white colored) wear out faster typically hard starting from cold = worn out reeds. I had an '86 CR 125 for a long time turst me it doesn't take no 15-20 mins when cold to start. When everything is in good order try more like 2 kicks when dead cold to start. Stock jetting was actually spot on from the factory. |
| Plug and mix arent ur problem. Also isnt the b7es a hotter one?? OT |
| Either your pilot jet is clogged, your float level is incorrect or you have low compression. Disassemble the carb, soak it in carb cleaner, blow it out with compressed air. The set the float level according to the manual. While you are at it, check the compression. Pull the manifold and make sure the reeds aren't chipped as well. BTW, when it runs, does it have a lot of blueish-white smoke? If so, you also have a crank seal that needs replacing. |
| Could it have something to do with the needle and the Jetting? could you just adjust the needle? would that make a difference? How do you adjust the floats? I don't have a manual and I am going riding/camping this weekend for memorial day weekend. What should I do to fix the problem? |
| There is a good pictorial posted by Faded in the archive section. Start there. I want to say 16mm is the float setting. Check his post for procedure. If yours has the pj carburetor as I believe it does, you can also try this: Screw the enrichenor all the way down. Don't just push it down,,screw it down tight. It helps with some chronic richness problems when those get old. It will no longer idle, but it is a cure for some of them that foul plugs. GET A MANUAL. You are pretty green it seems, and that will help a lot if you get it and read it. You can understand and ask better questions too. Last edited by ossagp1; 05-24-2006 at 12:58 AM. |
| 1986 RM 80 | shauny35 | 2-Stroke Motorcycles - Suzuki | 6 | 06-25-2009 04:12 PM |
| 1986 CR80R | Synyster06Gates | 2-Stroke Motorcycles - Honda | 0 | 11-20-2007 10:30 AM |
| 1986 cr 250 cylinder help | GRIZZ1981 | 2-Stroke Motorcycles - Honda | 1 | 09-26-2005 02:05 PM |
| 1986 RM80 | mullet1 | Motorcycles & ATV's | 0 | 09-13-2005 01:14 PM |
| 1986 YZ 80 for $350 | Woody_YZF | General Discussion | 36 | 05-12-2004 09:17 PM |
