Old 03-30-2016, 01:25 PM
CRzillaR's Avatar
Last Online: 06-29-2016 06:22 AM
Default 03 cr125 - Right crankcase cover wont go on
So i did new shaft oil seal water seal and bearing on my water pump, i am certain it is together correctly, but i cant get the right crankcase to slide on. I was having trouble getting that kickstarter thingy at the end before the spring on the inside: but the spring that hooks onto the case could that be causing it? I look around the inside i couldnt see anything blocking it ive pretty much narrowed it down to the kickstarter. Ive been kickin myself trying to get this back together.
Old 03-30-2016, 03:47 PM
JMV's Avatar
JMV JMV is offline
You might need to spin the water pump a little and try again. It won't go on if the primary gear and water pump gear don't mesh. Might take a few tries before you get them to slide together.
Similar Threads for: 03 cr125 - Right crankcase cover wont go on
HELP!! Right Crankcase Cover gusco 2-Stroke Dirt Bikes - Honda 11 01-21-2016 01:57 PM
1988 Honda CR125 rightside crankcase cover bvest57 Dirt Bike Restorations and Builds 2 02-12-2013 06:38 AM
Will a cr125 1997 left crankcase fit to a cr125 2000 right crankcase? beont 2-Stroke Dirt Bikes - Honda 3 05-20-2011 09:19 AM
01 YZ125 Crankcase cover deuscent 2-Stroke Dirt Bikes - Yamaha 0 07-03-2009 06:16 PM
'96 Honda XR200 Crankcase Cover Q GCNTSi 4-Stroke Dirt Bikes - Honda 0 02-12-2008 12:16 AM
