Old 01-20-2004, 11:37 AM
mxSteve's Avatar
Last Online: 10-12-2004 09:59 AM
Default 02 CR80 Jetting
My kids 80 spluges oil from the silencer that drips down onto the swingarm. Its mainly when my daughter rides it. She isn't riding it like she stole it. She is getting better though.
I read in a post that you can move the clip up to lean it. Should I try this before re-jetting?
What is the stock jetting size for the 02 cr80? How do the mark the jets? Do they have numbers on them?
Old 01-20-2004, 12:01 PM
Tdub's Avatar
Default Re: 02 CR80 Jetting
What brand oil are you using? Spooge is usually from excess/low grade oil, but the CR80s are jetted fat stock.
Old 01-20-2004, 01:53 PM
mxSteve's Avatar
I am using Maxima K2 at 50-1. I was told that i should only go as high as 36-1 and change the jetting to keep it from spuging oil.
Old 01-20-2004, 02:19 PM
Tdub's Avatar
OK
Old 01-20-2004, 03:24 PM
Faded's Avatar
Steve,
The jets are marked with numbers. The lower the number the leaner the jet. Needles are sometimes an exception. By moving the clip on the needle you are, in a sense, "rejetting". By using less oil per volume at your 50:1 ratio (vs. stock @ 36:1) you have richened the jetting across the board. If you plan on using the 50:1 ratio you will need to jet accordingly by leaning things out.
Old 01-20-2004, 04:05 PM
Dell30rb's Avatar
The stock jetting is a tad rich, but I have found it works well at sea level.
Leaning it out one notch on the clip wouldnt hurt.
Old 01-20-2004, 05:25 PM
mxSteve's Avatar
Thanks for the replies. I will try the clip up a notch. While I am in there I will see what jet size I have. I was also told to have the air screw out 1 1/2 turns. Is that a standard setting or is it specific to what jet you have and clip placement?
Old 01-20-2004, 05:30 PM
Faded's Avatar
It's usually the standard starting point. You'll most likely have to adjust it from there for your gas/elevation/weather/riding style. Also, there is more than just the main jet. I'd also look at the pilot jet # and the needle # while I was in there.
Old 01-20-2004, 05:40 PM
mxSteve's Avatar
Thanks alot! you guys are great.
Similar Threads for: 02 CR80 Jetting
Question about "winter jetting" ON CR80 terminator 2-Stroke Dirt Bikes - Honda 1 02-19-2007 01:42 PM
cr80 hondadad 2-Stroke Dirt Bikes - Honda 3 03-27-2005 06:44 PM
cr80 Jetting.....with New Exhaust System ripper65 2-Stroke Dirt Bike Forums 25 08-07-2004 06:14 PM
cr80 jetting..with New Exhaust system.. ripper65 2-Stroke Dirt Bikes - Honda 3 08-03-2004 04:16 PM
CR80 MidRange Jetting Help Needed CR250R Thunder 2-Stroke Dirt Bikes - Honda 7 02-29-2004 08:49 PM
