Old 05-10-2011, 12:46 PM
Last Online: 04-27-2014 01:07 PM
Default '02 CR125 plastic same as '04?
I see listings for plastic like '00-'02 and then '03-'07 but I always thought that CRs from '02-'08 were essentially the same. Does anyone know if the plastic is interchangeable for these years? Is it just the different front number plate and if so, does the newer design mount the same?
Thanks.
Old 05-10-2011, 08:24 PM
BK530's Avatar
Last Online: 12-14-2015 03:08 PM
just go to Service Honda and go to the OEM part finder and you can compare the different year parts numbers to make sure they work.
Old 05-15-2011, 10:51 PM
Yes, thanks. I'll check it out but sometimes that site shows a slightly different part number even though the part will actually still fit the different year or model.
Old 05-16-2011, 06:15 PM
Litewaite's Avatar
Last Online: 07-16-2015 08:16 PM
00-01 plastics wont fit
02-03 are the same
04-07 are the same as 02-03 except the front fender looks different but bolts up. The 04-07 front number plate wont bolt up. It bolts to the top of the triple clamp not the front. You could drill the number plate to make it fit.
Old 05-16-2011, 11:29 PM
02-03 are the same
Thanks! This is what I was looking to find out.
Old 05-17-2011, 07:46 PM
Litewaite's Avatar
No problem. Your Welcome. If you need to know most of anything else about aluminum frame cr250s and cr125s let me know
Old 05-17-2011, 11:22 PM
Thanks. I have a question you may know about CR125 Trannys. Which years had 5 speed and when did they go back to 6 speed?
Cheers.
Old 05-18-2011, 02:37 PM
Litewaite's Avatar
I had a 97 and it had a 6 speed tranny and a 00 and I believe it was a 5 speed if I remember correctly.
Similar Threads for: '02 CR125 plastic same as '04?
Where do you get plastic from? peeter the eeter General Discussion 0 05-24-2010 01:18 PM
KX 125 Plastic acw592 2-Stroke Dirt Bike Forums 6 11-14-2007 12:50 AM
cr plastic rriddle 2-Stroke Dirt Bike Forums 2 10-23-2006 01:45 PM
looking for new plastic davidandash ATV/UTV Forums 14 10-22-2004 04:38 PM
CR 125 PLASTIC ????? senatesk8r216 2-Stroke Dirt Bikes - Honda 2 03-28-2004 05:14 PM
