02 carb problem
This is a discussion on 02 carb problem within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; Im having problems with my carb flooding and overflowing out the tube when the gas is on. Ive changed the ...
Old 10-20-2005, 10:33 PM
1500cr250's Avatar
Last Online: 01-20-2009 08:36 PM
Default 02 carb problem
Im having problems with my carb flooding and overflowing out the tube when the gas is on. Ive changed the float valve and adjusted the float tang about 10 times within spec and it still leaks. Not as bad as before though. Before I would turn the gas on and it would leak really badly, now it takes about a minute or 2 after the gas is on and leaks some but doesnt pour out like before.
Is the float valve seat my problem? Do these normally need replacing?
What can my problem be?
2002 cr250
Old 10-21-2005, 11:11 AM
Kenny400's Avatar
Proud Papa
Last Online: 01-21-2010 12:39 PM
Default Re: 02 carb problem
I suppose its possible the float valve seat could have a small flaw or something like a piece of trash stuck/embedded, causing the needle valve not to seal off properly. Couldn't hurt to replace it and see how it goes.
The other thing might be that the float has lost some of its bouyancy(sp?) and isn't putting enough pressure on the needle when it floats to make the seal. Like it has become saturated with gasoline(if it is made out of a foam type of material) or sprung a leak and has partially filled with gasoline if it is the hollow type.
Old 10-22-2005, 06:58 PM
Jay547's Avatar
Last Online: 10-22-2009 07:35 AM
i finally got tired of messing with that mikuni. just buy a keihin for a '00 cr250 and be done with carb problems. i did. i couldn't be happier.
Old 10-22-2005, 07:01 PM
SirFallsALot243's Avatar
AKA Ineedabettrbike
I always prefer Mikuni over Keihn. Much less finiky.
Old 10-22-2005, 07:18 PM
Jay547's Avatar
you gotta be kidding.
Old 10-22-2005, 09:08 PM
AKA Ineedabettrbike
Ever tried to jet a Keihn?
Old 10-24-2005, 10:31 AM
1500cr250's Avatar
My problem ended up being the brittle O-ring around the float valve housing...
I also swapped in a 400 main jet (from 380) and went to the 3rd position on the needle and runs great.
Old 10-27-2005, 08:56 PM
mtk's Avatar
mtk mtk is offline
Mr. Titanium Implant
Yeah, many times. And generally speaking, the Keihins are better carbs. In the case of a 2002 CR250, the Keihin from a 2000 CR250 is worlds better than the POS Mikuni that Honda put on at the factory.
Old 10-27-2005, 09:15 PM
KX02's Avatar
Don't tase me bro!
Last Online: 04-13-2008 06:05 PM
Yeah, that's pretty much common knowledge that Honda is the only Japanese manufacturer too cheap to put Keihin Power Jet's on their 250's. I've heard of plenty of Honda guys switching to the Keihin themselves. I like mine alot! Responds quite well to jet changes.
Old 10-27-2005, 09:21 PM
AKA Ineedabettrbike
Ive always had more trouble with Keihn's. I guess I just suck at jetting.
Similar Threads for: 02 carb problem
Carb problem brlatm 2-Stroke Motorcycles - General Discussion 6 10-12-2007 01:03 PM
need help with a carb problem TG kfx 400 ATV/UTV - General Discussion 12 02-06-2007 11:43 PM
185 carb problem BA069 ATV/UTV - Honda 8 03-08-2005 06:35 PM
Carb Problem Need Help dinorex44 2-Stroke Motorcycles - General Discussion 22 01-24-2005 01:55 PM
Carb problem RacerCR125R 2-Stroke Motorcycles - Honda 10 07-22-2004 07:40 PM
