Old 05-04-2014, 05:30 PM
Detroiit's Avatar
Last Online: 05-20-2014 04:17 PM
Default 01 Cr250 Watch Video Please
Hi guys and girls,
It seems I'm having an Idle issue or possibly something more. After some warm ups and easy riding and and oil change my idle is still high and seems not right. The bike seems to have power and I am at 32:1 with klotz. The idle has been high since the rebuild.. I assembled the motor with grease in the pinion joint area. The power valve (CRV) seems to be functioning properly. I haven't done a leak down test/compression test. I installed a new OEM stator and haven't properly timed it correctly. (Going to get the light / tach on Tuesday) At the end of the video can you tell me what that "bird like" noise is when shutting off the bike.
Again thanks in advance
Ken
https://www.youtube.com/watch?v=fh_TGl8px2w
Old 05-04-2014, 07:56 PM
Last Online: 05-04-2014 07:56 PM
Sounds like ur running lean.I.e fatten up main jet sounds like my 96 when the temp changed 15-20 degrees. Would b a quik try
Old 05-05-2014, 09:19 AM
Randog Leader's Avatar
Check your float height and adjust accordingly before dorking with the jets.
---------- Post added at 09:19 AM ---------- Previous post was at 09:11 AM ----------
Don't rev the crap out of it until you get the fuel mixture correct. Lean condition can cause motor damage.
Old 05-05-2014, 09:32 AM
Detroiit's Avatar
If i adjust the carb now wont i have to redo it when it gets to 80/90+ Degrees?
Old 05-05-2014, 09:57 AM
KKXR400R's Avatar
Ken, have you done the carb conversion on this bike? the mukunis were a huge problem for this bike. Check the float bowl height and see how that works. Im sure you tried turning the idle down....right? . Also a chipped or cracked reed will cause similar symptoms. Hope this helps.
-Kevin-
Old 05-05-2014, 11:09 AM
Detroiit's Avatar
-Kevin-
I have not done anything to the carb except clean the outside of carb. I did check the reeds but only briefly. I will turn down the idle screw after i re-check the reeds. Any idea what that whistling noise is when shutting bike off? Is it a sucking air noise or new seals wearin in? Lol. Anyone?
Old 05-05-2014, 11:25 AM
KKXR400R's Avatar
Sounds good. Keep it simple and I'm sure you'll get nailed down. It's weird, it almost sounds like the high idle when the choke is on.....Let us know what you find.
-Kevin-
Old 05-05-2014, 03:31 PM
Detroiit's Avatar
borrowed a snap on tach/timing light. going to time it per manual than take it from there.
Old 05-05-2014, 06:54 PM
Detroiit's Avatar
Default New Video
I tracked down that bird noise I was hearing and it was coming from the cylinder to case gasket. I loosened it up and re-torqued it to 29lbs and the noise went away but there is still a slight air leak. I put my finger over that area and the idle come's down. I will be timing it up tomorrow. I messed with it today but i need to elongate the bottom setting plate. At 3000 rpm the f marks are not properly lined up. ( i seen a post from dogger, he was replying to a post from 2009 and dogger stated it should be timed at 5000 rpm. My manual says 3000 rpm. Did they supersede that rpm>?) anyway here is my vid from today's progress. Still not perfect but way better than yesterdays vid..
https://www.youtube.com/watch?v=OJsK...ature=youtu.be
Similar Threads for: 01 Cr250 Watch Video Please
must watch video crcraig General Discussion 4 12-11-2013 12:37 PM
Watch my new video quadrider32 ATV/UTV Forums 10 01-22-2006 08:35 PM
WATCH!Video Almost done! MxMike393 Photo & Video 24 03-16-2005 01:16 PM
A Must watch video! Spitfire General Discussion 4 12-12-2004 07:12 PM
WATCH MY VIDEO SO FAR!!!! MxMike393 Photo & Video 43 06-03-2004 12:58 AM
