Old 04-29-2014, 08:33 PM
Detroiit's Avatar
Last Online: 05-20-2014 03:17 PM
Default 01 cr250 Ignition Timing
I just recently finished my 01 cr250 rebuild and I installed the new stator. I put the top bolt in closer to the left/middle hole in the slot. (there is a oblong slot for stator to slide in for adjustment) ( i know this is a bad explanation ) Is there a general rule of thumb for someone that dont have timing light/ correct tools? Should I put the bolt smack dab in the middle of the stator? More right to Advance? more left to Retard? Is there enough adjustment to fry my system / burn hole in piston? Can I push it all the way ClockWise to advance it or should I really time it per the manual? I know jetting and other variables to consider but...
Thanks in Advance..
Ken
Old 04-29-2014, 09:33 PM
Last Online: Yesterday 08:16 PM
Adjust the timing as per the manual.
Old 04-30-2014, 07:57 AM
Randog Leader's Avatar
Should be some alignment marks. Not sure about your specific motor. If there are no marks, you will have to do as suggested and set the timing per the manual.
Just know that if the timing is too far advanced, you will probably hear pinging in the motor and could blow it apart. Bolts in the middle of the slots is where I would start if you have no access to timing tools.
Old 04-30-2014, 08:02 AM
stevo450's Avatar
There should be two alignment marks, one on the cases, one on the stator backing plate...
Line those dead on, then see what your manual has to say.
Old 04-30-2014, 08:12 AM
JMV's Avatar
JMV JMV is offline
Huh? I think people that know a bit more about ignition timing than you do wrote the manual...
Old 04-30-2014, 10:58 AM
Detroiit's Avatar
I know the proper way is the best way. I dont have a light/tach so was just wondering if its ans absoulate necessity
Old 04-30-2014, 11:14 AM
What you need if there are no marks is a manual, dial indicator and degree wheel.
The manual is still the best however.
Old 04-30-2014, 03:07 PM
Detroiit's Avatar
I have the manual and the stator / flywheel is brand new oem. I need to bring bike to 3000 rpm and time it but.. as stated before no light or tachometer. Looks like i'll have to get one!
Old 05-01-2014, 07:04 AM
Last Online: 03-09-2017 01:19 PM
I know here in Texas the auto supply stores will rent tools. O'rielly Auto or Auto Zone will, not sure what's available up in your neck of the woods. Might be cheaper than buying one.
E
Old 05-01-2014, 02:46 PM
Detroiit's Avatar
E
NICE! they do rent tools for free.. Have to pay the full price then get reimbursed when we return them..
Similar Threads for: 01 cr250 Ignition Timing
1995 KTM 440 EXC deck height - ignition timing fsmith46 2-Stroke Dirt Bikes - KTM 3 05-23-2011 01:45 PM
CR250 ignition InfernalVortex 2-Stroke Dirt Bikes - Honda 14 07-25-2010 10:38 PM
YZ2000 2-stroke Ignition Timing Problem davefordham 2-Stroke Dirt Bikes - Yamaha 7 12-02-2008 03:49 PM
Ignition timing.... 2001hondacr125 General Discussion 0 04-27-2008 06:58 PM
ignition timing 94 kx 80 ringdingding 2-Stroke Dirt Bikes - Kawasaki 10 03-13-2008 06:04 PM
