01 CR250 fork protector rubbing on fork tube
This is a discussion on 01 CR250 fork protector rubbing on fork tube within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; I have a problem with the OEM plastic fork protector rubbing on the fork tube (brake-line-connected right hand fork - ...
Old 02-27-2006, 11:29 AM
AustoUS's Avatar
Last Online: 09-23-2007 01:31 AM
Default 01 CR250 fork protector rubbing on fork tube
I have a problem with the OEM plastic fork protector rubbing on the fork tube (brake-line-connected right hand fork - looking at the bike).
Seems on the CR, a small wear ring sits at the bottom of the fork tube, which attempts to prevent the fork protector from contacting the fork tube. When the ring wears thin (down to the fork tube) ones fork protector rubs on the tube.
Ive attempted to adjust the front brake line, thinking the tension of the line connected to the fork protector maybe an issue - didnt seem to have an affect. Ive adjusted the position of the brake line on the protector - ditto. Ive also tried some rubber and thick tape to protect the tube - after a days riding, it needed to be replaced.
Does anyone have any recommnedations or opinions on ..,
-Have other riders experienced this problem with the CR?
-Are there after-market wear rings which are "thicker" or more durable?
-Are after-market (ufo, acrebis) fork protectors a different fit or shape? Is there less wear on the wear ring/tube using these aftermarket products?
-Other solutions?
Thanks!
Old 02-27-2006, 11:34 AM
Silver_Fox's Avatar
Wut the?
Last Online: Yesterday 05:10 PM
Default Re: 01 CR250 fork protector rubbing on fork tube
Replace the wear ring.
Old 02-27-2006, 12:01 PM
Crazy's Avatar
Accident Prone
Last Online: 12-29-2009 11:11 AM
Yep do what Silver Fox said. It just looks like a metal ring around the fork. Mine was bad and caused the same problem on my 01.
Old 02-28-2006, 07:27 AM
nhunti's Avatar
Last Online: 03-06-2009 09:55 AM
Default heres what i did.
on my 01' cr-250 i have the same exact problem. it stems from the constant pulling by the front hydraulic hose going to the brake. this fatigue weakens the 3 bolt holes in the plastic guard and it begins to tip toward the fork.
The large plastic front brake disc guard is not needed, the bike looks much better without it. the disc guard is secured by 2 bolts. by freeing these 2 bolts i made a brace that bolts to the 2 disc guard holes. then bends up
135degrees to bolt to the hydraulic line clamp at the top of the fork guard. i made this brace to provide a forward pull on the fork guard keeping it away from the fork. i made mine out of stainless steel for strength and corrosion resistance.
if you are interested in seeing a picture of the brace, post your email address on a following reply to the original thread you wrote and i will send you a picture of it.
later.
Old 02-28-2006, 02:44 PM
AustoUS's Avatar
Thanks nhunti - send your pix to [Only registered and activated users can see links. ]
Old 03-02-2006, 06:35 PM
Last Online: 03-14-2010 02:22 PM
I have the same bike and had the same problem. Now this will sound silly. . . .but it works. Get a large zip tie from the hardware store. The ones that are about 3/8" wide. Tie it to the bottom of the fork where the guard rubs. Use some pliers to pull it really tight so it will not come loose easily. This will let the fork guard rub on the tie and not the fork tube. WHen it wears out, replace the zip tie. Cheap and effective!
DPinDet
Old 03-03-2006, 05:35 AM
Reuel's Avatar
Have bike, will jump.
Last Online: 09-19-2007 07:49 PM
Hey the thick zip tie is a great idea. I have the same problem with my 2000 CR. What helped me was to loosen the brake cable bolts and the two bolts that hold the fork guard. Then I grabed the whole thing and mossed it into a better position making positively sure the brake cable was not stressing the guard. I still like the heavy duty zip tie idea.
Old 03-03-2006, 06:10 AM
kuritaro9's Avatar
might consider BIG BLUE
what i did on mine was, i bought a set of CF yzf wear rings, removed the stock wear rings, then intalled the CF ones with some double sided H/D tape...its looks a lot like the setup RC ran on his works hondas, and looks cool too...oh yeah, i got'em from the ATM store also...
Old 03-03-2006, 06:29 AM
kuritaro9's Avatar
here is a link to the ones i got from the ATM store...
http://www.allthingsmoto.com/shop/pr...roducts_id=147
Old 05-23-2006, 08:28 AM
Last Online: 11-23-2009 09:16 AM
Those are cool, didn't even know such a thing existed
Old 07-26-2006, 10:20 PM
Last Online: 07-31-2006 10:06 PM
Did they discontinue those rings? Im not seeing them???
Old 07-26-2006, 10:34 PM
I've been RM-Zedded
Shoot a PM to my brother (Woody_YFZ) and he should be able to tell you the status on those.
Old 07-26-2006, 10:45 PM
Woody_YZF's Avatar
www.motorsportsofutah.com
I'm not sure what happened to the item in the store?? Kuritaro, was it Lightspeed brand, do you remember? If so, we can still get them.
Old 07-27-2006, 06:33 AM
kuritaro9's Avatar
no, they were made by ride engineering....i ordered both sets of them from the ATM store.
PN: YZ-FWG05-CF from the ride-engineering website
Old 07-27-2006, 03:30 PM
Woody_YZF's Avatar
Unfortunately we no longer carry Ride Engineering products. For some reason our distributor stopped carrying them.
Old 08-26-2006, 02:30 PM
Last Online: 12-15-2006 10:43 AM
i use these big black zip-ty's i got at the local swap meet for $1
the black ones are sun resistant and they hold up pretty good
Similar Threads for: 01 CR250 fork protector rubbing on fork tube
Fork tube drop? hardcore 2-Stroke Motorcycles - Honda 3 04-07-2006 11:23 AM
Fork tube height? redrider4 2-Stroke Motorcycles - General Discussion 6 08-02-2005 03:49 PM
Major fork tube problem WhiskeyThrottle Motorcycle Suspension Tuning 4 08-25-2004 05:11 PM
New Fork Springs Rubbing? Trip McNeely Motorcycle Suspension Tuning 3 06-28-2004 07:27 PM
DOH fork tube problem Crazy Motorcycle Suspension Tuning 17 06-21-2004 07:19 PM
