01 CR250 cutting throttle slideThis is a discussion on 01 CR250 cutting throttle slide within the 2-Stroke Motorcycles - Honda forum, part of the 2-Stroke Motorcycle Forums category; Originally Posted by junteschan1
YZhallsme,
Sorry for the late reply. Yes, I still have the S-4 installed combined w the ... |
#81
FWIW I tried again to take some measurements of JD red vs. stock needle, can post or pm you what I came up with if you want. Last edited by YZhallsme; 05-09-2009 at 09:30 AM. |
#82
| I managed to get in 50 miles with the stock 6beh1-73 needle in clip #3, S-4 nozzle, 27.5 pilot, 370 main, stock #4 slide, airscrew 2 1/4 out. Elevation was @ 8,000' and @ 65*. It ran pretty good, didn't notice any sign of being too lean, no overheating, no bog or flat spots, no decel surging. However this was with 100 octane Sunoco, not the usual pump premium. |
#83
Mine I expect at probably 90F w 91 octane....let you know of course. |
#84
| Update- Back to 91 pump premium, everything else remained the same. Only rode 17 miles at @ 70*, 8,000' and dry. I also attempted the "Wet Oil Line" or is it "Pull The Pipe Method" of checking 2 stroke jetting but I couldn't distinguish the line (I'll keep trying). No signs yet of being too lean while riding, airscrew seemed best around 2.25 out, think I'll try a smaller pilot next time. What I did notice at the end of the day was that while the spooge running down the outside of my silencer looked to be the same, the inside of the silencer looks as if it's drying out! This is the first time I've ever seen that on this bike. Also when I got home I pulled the plug, the metal portion at the base of the threads was dry, another first!! Not sure what to make of it though??? |
#85
| Update: Barstow California, Saturday June 20 and Sunday June 21, elevation 2100 ft, temp 90F Saturday late afternoon, Sunday morning, 65 early-85 by noon. Ran soooooooooooooooooooooo great. Crisp, clean, linear. Bottom to mid end was "electric", mid to top she would sing, I really mean sing, the pipe would actually resonate with this, most beautiful note. I love it. Only had to adjust the air screw 1/8 turn out to get her to idle like a champ. Got around 25-29 miles to the gallon. Plug was a little dark but acceptable. The only smoke visible was a very light wisp right after a wrap of the throttle. I have only had her out on the track since I did the jetting. I am not a good enough rider to wring her out on the track so I really didnt know how well she would run for long periods of time in the top end of the throttle. This weekend proved that you can make one of these pesky Mikuni's run great thanks to JD. Last edited by VAL; 06-22-2009 at 04:14 PM. |
#86
| So you say you can get the bike to idle good with the jd kit .Im in heavy debate on whether to go with the jd kit or 38 airstriker .....Im at about 900ft above sea level and temp range from 60 to 90 when i ride,what would be a good starting point with the jd kit? |
#87
With this ride of yours....what are your specs again.... many thanks of course. ---------- Post added at 10:30 PM ---------- Previous post was at 10:12 PM ---------- Quote:
one thing i noticed w the mikuni tmx is that the needle jet is easily removable and will allow various sizes for your choice of tuning. whereas, the keihin a/s is fixed i think .....tinkering with it is the fun side of it and some 01cr250 owners such as val,yzhallsme & myself get to give us test results thereafter.... really many thanks to them...my bike runs much better and im having more fun. Good luck to you.... |
#88
| Gota give thanks to val ,hey i noticed on the service 250 honda that it has a pwk carb on there.Im still undesided .. |
#89
| I am running 380 main, JD red needle, clip @ 4th from top, 4S nozzle, 25 pilot, air screw 2 5/8 out (at 2100 feet) and idle screw ~ 1/4" of threads showing past the lock nut. Last edited by VAL; 06-23-2009 at 08:46 AM. |
#90
many thanks....you and YZhallsme have been very helpful doing the tests on this tmx carbs......appreciate it. |
| Tags |
| cr250, cutting throttle slide |
| 2002 CR250 Cutting out. | low430 | 2-Stroke Motorcycles - Honda | 23 | 04-14-2008 08:44 PM |
| Jedi's Slide! | pjg351 | General Discussion | 1 | 01-09-2008 07:46 PM |
| Throttle slide height adjustment 04 cr125 | MGCR125r | 2-Stroke Motorcycles - Honda | 0 | 11-24-2006 04:56 PM |
| Scary Slide! | Supermoto | Photo & Video | 18 | 07-25-2005 05:07 PM |
| How do I know what slide I have on an 01 cr250? | Mike[socal] | 2-Stroke Motorcycles - General Discussion | 4 | 07-14-2004 01:07 PM |
