![]() My 01 cr125 will only start with starting fluid. One it's warm it fires first kick. It has a new piston, head gasket, crank seal, and wp seal. The float was sticking so I rebuilt the carb, and now it won't start cold without a shot of starting fluid. After it's hot it fires first kick. Any suggestions? |
![]() Dirty or otherwise clogged pilot jet. Run a welders tip cleaner through it and clean with carb cleaner. Paw Paw Last edited by PawPaw; 08-14-2011 at 05:11 PM. Reason: spelling |
![]() if you do the same test running raw gas down the caburetor on through the spark plug hole you will find it probably works the same and bears out what PAW says. By the way, remembering the old rhyming song, just what is a PAWPAW and what is a pawpaw patch like anyway? |
![]() Quote:
I remember that too, but my name comes from my grandchildren. Thats what they have called me for about 17 years now. Paw Paw |
![]() Quote:
Mine just calls me papa. God I felt old when she started that. |
![]() Aww pipedown, you two are both likely younger than me. ![]() |
![]() I don't think so.... Paw Paw |
![]() Yeah, I probably am. 53 and I've been a papa for 10 years. I started young ![]() The fun part was calling my exwife "granny" when she was 40!!! |
![]() well Paw, I sincerely hope you are older, I turned 60 in may. |
![]() Well lets just say I am much older and let it go at that. Paw Paw |
Thread Tools | |
95 Cr125 not starting | hunter77ah | 2-Stroke Dirt Bikes - Honda | 9 | 11-29-2009 10:01 PM |
help....cr125 95 not starting | neenor | 2-Stroke Dirt Bikes - Honda | 4 | 10-27-2009 04:49 PM |
1998 rm 250 not starting w/o starter fluid | dlax2846 | 2-Stroke Dirt Bikes - Suzuki | 2 | 08-23-2009 06:13 PM |
CR125 starting problems | InvolvedPatriot | 2-Stroke Dirt Bikes - Honda | 8 | 01-18-2005 08:07 AM |
1986 Cr125 starts but bogs as soon as you start to move. | DirtDoug | 2-Stroke Dirt Bikes - Honda | 9 | 12-10-2003 04:38 PM |
