Old 07-02-2014, 07:24 PM
Last Online: 07-03-2014 11:32 PM
Default 01 cr 125 rebuild questions.plz help
Hello every one I am new to this forum and new to wrenching on bike.my 01 cr 125 r has engine issues.it runs and starts every time but there is no power band on the top end. I pulled everything apart but the motor. The carb was brand new cleaned the air filter and cleaned the power valve.the piston was smoth looking but it is a little brown on the bottom side of the rings on the exhaust side. Reeds looked fine wasn't a huge gap on them but what do I no.so I was thinking about just having me and my buddies rebuild it.so was wondering if there was a difference in a top end kit or a top end rebuild kit and if there is anything else I should try be for tearing it apart.i no this might be a common post but every ones problems are different plz help me and I apreciate the input.
Old 07-03-2014, 06:07 AM
FRODAD393's Avatar
Last Online: 03-19-2017 10:03 AM
The 01 CR125 in stock trim is notorious for having no low, a lousy mid and an even lousier Top end. How did the bike run before the rebuild?
Old 07-03-2014, 03:25 PM
JMV's Avatar
JMV JMV is offline
If the bottom of the piston is brown, that means you are too lean. The piston gets too hot and the charge that's in the crankcase burns a little brown spot on the underside of the piston. If you're too lean, you're not going to get good power.
Edit: Those motors are notorious for having very little low end power, but mid and top are so-so.
Old 07-03-2014, 08:00 PM
Bike ran great all of a sudden no powerband at all no rebuild yet.
Similar Threads for: 01 cr 125 rebuild questions.plz help
RM 125 Rebuild Questions cmorris1711 2-Stroke Dirt Bikes - Suzuki 4 06-19-2014 10:13 AM
rebuild questions Billi29 4-Stroke Dirt Bikes - Honda 1 03-04-2014 01:54 PM
top end rebuild questions 4xjeepin4 2-Stroke Dirt Bike Forums 1 01-16-2008 05:43 PM
Top end rebuild questions Conrad#356 2-Stroke Dirt Bike Forums 6 01-09-2008 05:47 PM
Top end rebuild questions stressboyxr 4-Stroke Dirt Bikes - Honda 1 02-05-2007 12:19 PM
