yz85 spark plug fouling
This is a discussion on yz85 spark plug fouling within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Hi,I just purchased a used 2004 yz85. It runs fine for a day or two, then the spark plug fouls, ...
Old 04-30-2005, 10:49 AM
Last Online: 07-25-2005 03:28 PM
Hi,I just purchased a used 2004 yz85. It runs fine for a day or two, then the spark plug fouls, we clean the plug and it starts but will not run like before. Then it just dies within a short time. When I put a new plug in it does the same thing. Runs for a day or two and then it dies again. We are using BR10eg/NGK spark plug. 32:1 gas/oil ratio. If anyone could help me with this problem I would really appreciate it. Thanks, Tonimarie
Old 04-30-2005, 01:45 PM
trickSX's Avatar
Last Online: 08-26-2006 12:43 AM
Default Re: yz85 spark plug fouling
Try going down to a BR93g, but you just might not be riding it hard enough
Old 04-30-2005, 02:40 PM
mtk's Avatar
mtk mtk is offline
Mr. Titanium Implant
Your jetting is wrong.
Changing spark plugs is treating the symptoms, not the actual disease. Fix your jetting and plugs will last indefinitely.
Old 04-30-2005, 02:58 PM
Yzrider054's Avatar
I <3 Yamaha's
Last Online: 03-15-2008 07:57 PM
you are either not running it hard enough or the jetting is off ! remeber a perfectly jetted 2 stroke will go a long ways on a plug.
Old 04-30-2005, 03:04 PM
SirFallsALot243's Avatar
AKA Ineedabettrbike
Last Online: 07-22-2008 02:44 AM
You should be able to ride it as slow as you want without fouling a plug. A plug shouldnt ever foul from not riding it hard enough. Jet it.
Old 04-30-2005, 08:56 PM
ShaneRider's Avatar
xxx
Last Online: 06-22-2008 12:41 PM
Default JETTING
It's more than likely your jetting. Get that fixed.
Old 05-03-2005, 01:10 PM
robertc's Avatar
Retired...For Now!
Last Online: 07-19-2008 09:29 PM
its' not jetting. when i first got my 2 stroke i fould about 5 plugs until i learned to ride it. If ur just riding around slow, every few minuts, pull in the clutch and revv it. It has been about 4 months since i've fouled a plug once i learned how to ride a 2 stroke.
Old 05-03-2005, 01:12 PM
Silver_Fox's Avatar
Wut the?
Last Online: 11-19-2009 11:50 PM
Originally Posted by robertc
its' not jetting. .
Yes it is.
Old 05-03-2005, 02:30 PM
FFRacing11x's Avatar
The "ONLY" FastForward
You might have learned how to ride it(??), but you haven't learned how to jet it!
Old 05-03-2005, 02:35 PM
Mr.Boof's Avatar
Banned
Last Online: 07-17-2005 11:42 PM
go to a 132 main jet... it happpened on my friends yz
Old 05-03-2005, 04:04 PM
mtk's Avatar
mtk mtk is offline
Short and sweet: you're wrong.
Your jetting is off and rather than correct it, you're trying to limp around the problem.
Your options are: A) fix it right by rejetting, or B) continue to do the stupid "clutch in and rev it" BS in an effort to keep from fouling plugs.
Old 05-03-2005, 07:24 PM
Doom Crew's Avatar
Wreckin Ball
Last Online: 03-04-2008 12:39 PM
Yep, my buddy had this problem just rejet it and you should be fine.
Old 05-03-2005, 08:01 PM
ShaneRider's Avatar
xxx
Default It's not bad...
It won't kill you if you feather the clutch a little bit even when your jetting is fixed. Feathering will get you on the power faster.
Old 05-03-2005, 10:26 PM
robertc's Avatar
Retired...For Now!
well, i guess you can re-jet. i didn't on my bike but since everyone seems to say that u should, i guess they are right.
Old 05-03-2005, 11:29 PM
mad_biker's Avatar
blue (or yellow) is better
Last Online: 10-27-2009 07:35 PM
i'd probly just get the next 3 smaller main jets and start with the bigger of the three and go smaller if needed .
Old 05-05-2005, 11:53 PM
There is a good post by Faded on setting a float. Buy all the jets and turn all the screws you want, and you will still not be as crisp as you could be if that simple item was set right. From there I would work with the low speed screw. Turning it in will place more fuel in the fuel air mix and likely increase your fouling. Turning it out will lean out the low speed circuit. If you have to go more than 2.5 out, consider the next smaller pilot jet.
There are lots of threads on here about jetting. Some are pretty good.
Jetting is on a "per rider" basis. Most any rig can be jetted for the type of riding and the type of rider.
I see nothing wrong with changing a heat range to get a certain affect, but changing it because you are fouling plugs is as MTK said, just treating the symptom.
Similar Threads for: yz85 spark plug fouling
2006 CR125 Fouling Spark Plug Rando592 General Discussion 7 01-13-2009 09:35 PM
plug fouling Leech 2-Stroke Motorcycles - Honda 3 08-05-2007 08:23 PM
Plug fouling Leech 2-Stroke Motorcycles - General Discussion 1 08-05-2007 08:10 PM
PLUG FOULING bradm 2-Stroke Motorcycles - General Discussion 1 11-12-2006 11:02 PM
Fouling/Spark issue, wet plug Crazy 2-Stroke Motorcycles - Yamaha 58 05-31-2004 08:40 PM
