Yz250 clutch nightmare!!!
This is a discussion on Yz250 clutch nightmare!!! within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Can any of you lovely people out there please help with some advise on my 1999 yz20 clutch? I have ...
Old 07-26-2009, 12:58 PM
Last Online: 07-28-2009 09:24 AM
Default Yz250 clutch nightmare!!!
Can any of you lovely people out there please help with some advise on my 1999 yz20 clutch? I have purchased new plates, but am not sure what to do next, ive had the outer casing off and cant see any raeson why its not working!!!! What am i doing wrong???? Any advise would be greatly appreciated! Thanks
Old 07-27-2009, 08:09 AM
MXtras's Avatar
Manufacturer
It would help to know what it is doing.
Replacing the friction discs is pretty simple - remove the clutch cover then remove the hat from the basket, remove the old discs and replace. You can do it without even loosing any oil if you lay the bike over on it's left side.
Scott
Old 07-27-2009, 08:24 AM
Last Online: 11-12-2009 08:32 PM
yeah its not really too hard, when you take the cover off, remove the five or six bolts and springs. you wont really be able to tell the difference until you hold the stack of new plates and compare those with the old ones. you should be able to tell a difference in height, as in the new plates are thicker. this is good, and the reason your discs are bad is because the old ones arent thick enough to grab.
the new pack should come with directions. if not, just put the new ones in the way the old ones came out. i have a honda but its probably the same. with mine its steel, friction, steel, friction, etc.
when they are all in put the basket cover on and then the springs and bolts.
next you put on the clutch side cover, put in new oil, and ride your bike.
Old 07-31-2009, 01:06 AM
Last Online: 09-13-2009 02:03 PM
before you put new plates in you need to soak them in tranny oil. And I believe on the yamahas you should start with a friction and end with a friction. The old clutch will look fine, but they do burn up, it happens!
Old 07-31-2009, 11:19 AM
Last Online: 09-12-2009 09:50 PM
Make sure it IS the plates! How many people replace plates over and over and that's not it. On an older bike I would DEFINETELY replace the springs as they are cheap anyway. They DO fatigue especially if it has been really hot from slipping. Also, check for how much wear is on the pressure plate. This is the outer most aluminum piece that first comes off after the bolts and springs. These are about 90 bucks from yamaha but I guarantee it is probably worn out if you are ahrd of the clutch.
Just soem things to check, no one ever told me. Took a while to learn. in my opinion it is seldom the darn plates.
Old 07-31-2009, 12:59 PM
FFRacing11x's Avatar
The "ONLY" FastForward
Soaking the plates is not required. When you start the bike up just disengage the clutch a few times and they will have all the oil they need. "Soaking" is a misnomer...the oil does not actually penetrate the fibre. The factory does not soak them on your new bike! JMO Tdub
Old 08-02-2009, 02:36 PM
Last Online: 08-05-2009 03:32 PM
have you tunr the outer clutch disk(the one hold by springs) into right position?
its easy to turn it wrong and the clutch donīt work because disk will get stuck on the inner wheel..
Similar Threads for: Yz250 clutch nightmare!!!
82 YZ250 CLUTCH BASKET Cappy 2-Stroke Motorcycles - Yamaha 1 05-04-2009 10:55 PM
89 YZ250 clutch cover ??? duffysp 2-Stroke Motorcycles - Yamaha 6 05-06-2008 10:32 PM
05 YZ250 Clutch Cover (pics) Satch0922 2-Stroke Motorcycles - Yamaha 67 11-03-2005 07:29 PM
Rekluse auto clutch in YZ250 and more.... Racerafm50 2-Stroke Motorcycles - Yamaha 12 06-21-2005 11:06 AM
1995 YZ250 Clutch problem icantslowdown 2-Stroke Motorcycles - Yamaha 5 09-20-2004 09:34 AM
