Old 03-19-2018, 05:40 PM
Last Online: 04-15-2018 12:15 PM
Default Yz125 bottom end kit
I'm going to be doing a bottom and top end rebuild on my 2003 yz125. I'm going with the wiseco piston, but need to hear some opinions on the bottom end. I've read the wiseco cranks are utter **** and I should go with hot rod. Has wiseco done anything about this recently, or should I stray from using their cranks?
Old 03-19-2018, 08:03 PM
Any replacement crank should be checked for runout prior to the install to insure it's life. Far too many come from the factories with the runout being off a good bit. If installed as it comes out of the box it can fail in short order.
Old 03-19-2018, 08:16 PM
Any links you can refer me to in order to check this? Also, are you saying that the wiseco cranks are fine as long as the runout is on point?
Old 03-20-2018, 11:00 AM
Service manual shows how to check run out and what the spec should be. I have heard the horror stories as well, but my experiences with wiseco and hot rods both have been good. I have a trail ridden yz250 with a wiseco crank that probably has more than 100 hours on it. I put one in a friends crf250 that went just over 100 on the hour meter before it failed. He actually got more out of it than the stock crank. These are my experiences. Ymmv
Similar Threads for: Yz125 bottom end kit
99 yz125 bottom end nightare extravaganza! sammittrue 2-Stroke Dirt Bikes - Yamaha 26 08-13-2015 08:28 PM
99 yz125 bottom and top questions sammittrue 2-Stroke Dirt Bikes - Yamaha 4 02-14-2015 04:47 PM
WTB: 05^ YZ125 bottom end CR80Rider Classified Ads 0 10-22-2010 07:05 PM
1994 YZ125, Do I need a bottom end rebuild? newstylecustoms 2-Stroke Dirt Bikes - Yamaha 3 05-02-2010 07:00 PM
Pipe with most bottom end for 05 yz125 mad_biker 2-Stroke Dirt Bike Forums 15 05-06-2005 01:04 PM
