All Things Moto! Web Forums
YZ 250 project need a carb expert
This is a discussion on YZ 250 project need a carb expert within the 2-Stroke Motorcycles - Yamaha forum, part of the 2-Stroke Motorcycle Forums category; Ok ive grown up on ATV's. I hate twist throttles on dirt bikes, so I put a thumb throttle on ...
Old 07-12-2005, 12:29 AM
Last Online: 05-21-2008 11:59 PM
Default YZ 250 project need a carb expert
Ok ive grown up on ATV's. I hate twist throttles on dirt bikes, so I put a thumb throttle on my YZ250. Best thing I ever did. Ive got much better throttle control than I did with the twist throttle. But it doesnt quite have enough throw. So im not quite getting WOT. I was wondering if a tri z 250 carb would work on my YZ? that way I can use a thumb throttle and cable from a Tri Z. Whatta ya think?
Old 07-12-2005, 12:58 AM
iggys-amsoil's Avatar
Last Online: 11-14-2005 09:00 PM
Default Re: YZ 250 project need a carb expert
You gota be kind us right? I understand the atv part cause I use to have one.
See if the tri Z carb is the same dia bore. I bet its samller.
If you get it done let us know when the front dances out of your right hand cause your thumb isn't wrapped around the bar.
Thats the very reason why I put a twistie on my 250R 3 wheeler.
Old 07-12-2005, 11:32 AM
I would absolutely kill myself with a twist throttle. Twist throttles are great on street bikes but not for me on dirt bikes.
Old 07-12-2005, 01:47 PM
RaptorRacer888's Avatar
Last Online: 07-22-2006 01:34 PM
I have heard on twist throttles on Quads, but Thumbs on dirtbikes....lmao.
I dunno, I like thumb on my Raptor. And I like the twist on my YZ 250, but if I ever switched them I think I would die.
Old 07-12-2005, 07:04 PM
Vintage Dave393's Avatar
ATM History Professor
Were you able to mount a cooler and gun rack on the YZ?
Old 07-12-2005, 08:41 PM
Spitfire's Avatar
Banned
Last Online: 08-10-2006 02:25 PM
MeCrazyPerson had a thumb throttle on his CR 250, he lost a good amount of movement in his right hand somehow, and couldn't twist the throttle on the 250, so he mounted a thumb throttle. Hey, whatever floats your boat right!
Old 07-13-2005, 12:28 AM
Yeah dont put it down if you havent tried it guys. Everyone that has riden it loves it. Im used the Rappy thumb throttle so I thought what the heck I will try it. I wish I could put a cooler on it. HMMM maybe that will be my next project. LMAO
Old 07-14-2005, 03:54 PM
You guys are a bunch of jerks aren't ya!! Man ive never seen such a bunch of haters. Try something a little different and everyones a . Not cool!!
Old 07-14-2005, 04:02 PM
Crazy's Avatar
Accident Prone
Last Online: 10-25-2009 10:00 AM
OR you could try using a throttle cam? I would assume them make them for thumb throttles like they do twisties. This would allow you to use the full range instead of having to swap out the carb.
Old 07-14-2005, 04:04 PM
char393's Avatar
Incretacular!!
Hey Ace..could you tone down the language a bit, please? I agree that a few people on here have been jerks.
Secondly, you should do a search on here for a previous user who went by "mecrazyperson". He had wrist problems and did exactly what you're describing on his CR250. I just can't remember if there was a post detailing it or not.
Old 07-14-2005, 04:06 PM
char393's Avatar
Incretacular!!
Err, sorry I didn't see that Spitfire had already mentioned mecrazyperson.
Old 07-14-2005, 04:28 PM
What is a Throttle cam crazy? I am not familiar with them. I apologize but I dont ask these questions or make these comments on here to be spoken to like an idiot. If you dont have anything to say about the topic, do not comment. I dont want to here BS. Thanks Crazy
Old 07-14-2005, 04:38 PM
char393's Avatar
Incretacular!!
It would seem to me all you would need is a thumb throttle assembly and possibly a different throttle cable? Can't you get throttle cables made to the size you need?
Old 07-14-2005, 04:44 PM
Never thought about that KDX. I bet I could. Thanks I will check into that.
Old 07-14-2005, 05:10 PM
quadfather03's Avatar
Last Online: 07-26-2009 01:06 AM
easy fix ace all you need is a universial throttle cable that adjusts in the middle. the problem you are having right now is that your thumb throttle doesnt use enough cable to pull the last few mm out i bet you even have it adjusted all the way out. You can get a universal cable for around 20 buck that will adjust longer or shorter thats what id do. And on the different thing i have a twist on my quad as well as my dirtbike once i got used to the twist on my bike i could control it like crazy and it is smoother than my old thumb throttle but hay thats your thing hope you enjoy it.
Old 07-14-2005, 11:01 PM
excellent Idea. Yes it is adjusted all the way out. LOL Universal throttle cable sounds like the fix I need. Thanks quadfather. And thanks all for the suggestions.
Old 07-17-2005, 07:29 PM
Last Online: 10-02-2005 11:07 PM
Default thumb throttle
I broke my right wrist in 2000 and had to have it fused. Since then I have been forced to ride with a thumb throttle. I love the control it gives me except when descending technical trails because my thumb isn't wrapped. I have raced 3+ hour desert races in Utah with a thumb throttle and as long as the spring in your carb isn't bad (which on a 38 PWK it isn't) it's not too fatiquing at all. I have purchased a Terry Cable ([Only registered and activated users can see links. ]) throttle that is beautifully crafted and works great. Each time I buy a new bike I just call Terry cable and tell them the carb that is on my new bike and they make a custom cable to fit. The throttle was about $120 and each cable runs about $25. Perfect fit and finish and full throttle pull as well. I just bought a 2005 YZ250 last week and ordered the cable for it. It should be here any day. Here is the contact info :
Phone Numbers Email
Phone:
(800)854-4691
Fax:
(760)244-0136 [Only registered and activated users can see links. ]
Old 07-17-2005, 08:10 PM
char393's Avatar
Incretacular!!
excellent info rjpyne!
Welcome to ATM!
Old 07-17-2005, 08:31 PM
That is awsome info. I will give them a call this week. Thanks rj
Similar Threads for: YZ 250 project need a carb expert
Flat Slide Carb vs. Piston Valve Carb cr85racer24 2-Stroke Motorcycles - Honda 1 09-20-2009 10:38 PM
engine expert please! Ricksta 2-Stroke Motorcycles - Honda 2 04-21-2009 08:29 AM
Expert riders, what does it take Drew778 General Discussion 32 06-17-2008 09:10 PM
05cr85r expert ??? kevstyle 2-Stroke Motorcycles - Honda 24 10-03-2005 12:45 PM
cr 80 expert help anticr85expert 2-Stroke Motorcycles - Honda 11 05-18-2004 08:40 PM
